Reply
Highlighted
Follower
Orbi Tri-band Whole Home Mesh Wi-Fi System with 2.2Gbps Speed (RBK23)
Hi
I have just bought this and do not seem to ba able to get it to work unless it is plugged into the existing TalkTalk router?
It seems odd to have a TalkTalk router and then the ORBI Router.
Can anyone advise please?
Philip
Message 1 of 2
Highlighted
Guru
Re: Orbi Tri-band Whole Home Mesh Wi-Fi System with 2.2Gbps Speed (RBK23)
Modem Combo Units:
This would be a double NAT condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
@PAFS wrote:
Hi
Philip
My Setup (Cable 900Mbps/50Mbps)>CAX80>XR450 v2.3.2.106(Router Mode)>RBK853 v3.2.11.2(AP Mode)
Additional NG HW: C7800/CM1100/CM1200/CM2000, Orbi CBK40, RBK853, R7800, R7960P,
EX7500/EX7700, XR450 and WNHDE111
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 205 views
  • 0 kudos
  • 2 in conversation
Announcements
