Orbi WiFi 7 RBE973
Reply
Orbi VPN for Smart TV Orbi RBR50
kornholio64
I have an Orbi RBR50 and I'm trying to use the VPN for my Roku box (mainly to watch Netflix), but I can't seem to make it work.
Message 1 of 5
Guru
Re: Orbi VPN for Smart TV Orbi RBR50
What FW is currently loaded?
https://kb.netgear.com/31489/How-do-I-use-VPN-on-my-Orbi-system-with-my-iOS-device
Message 2 of 5
ekhalil
Master
What VPN are you trying to use? Are you trying to establish VPN while attached to Orby towards a remote destination or VPN towards Orbi from outside?
Message 3 of 5
kornholio64
Please see the image, I'm asking for the VPN settings that the Orbi has in the advance options
Message 4 of 5
ekhalil
Master
The VPN settings in Orbi allows you to use a computer or a smart phone to establish a VPN tunnel from outside your home via internet to your Orbi at home so you can access the home devices as if you are at home.
The Roku is attached to your home Orbi so you can use a smart phone to connect a VPN to your home while you’re outside to be able to use the Roku as if you’re at home.
Is this what you want?
Message 5 of 5
Top Contributors
Discussion stats
  • 4 replies
  • 1629 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 7
