- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Orbi WITHOUT modem
- Mark as New
- Bookmark
- Subscribe
- Permalink
Orbi WITHOUT modem
Hello! How can I install Orby Wifi System without modem? I only have ethernet cable that connects to the router. I haven't got modem.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Orbi WITHOUT modem
As long as you have network/internet connectivity via that ethernet, you're fine. Modem is just a method to do so.
- Mark as New
- Bookmark
- Subscribe
- Permalink
My ethernet has login and password(from provider)
It won't be a problem?
- Mark as New
- Bookmark
- Subscribe
- Permalink
@russian wrote:My ethernet has login and password(from provider)
Orbi supports Internet connections that require login and password.
Orbi is not a modem. If your Internet connection requires a modem (such as cable or DSL) then Orbi will not work without a separate modem.
Why do you think you might need a modem?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Page 24 of the manual describes this:
http://www.downloads.netgear.com/files/GDC/RBK50/Orbi_UM_EN.pdf
If your ISP requires a login/password, you select the encapsulation method - PPPoE, PPTP, or L2TP. Does your ISP use one of these? Can customers of your ISP use other consumer routers? If so, thats a good indication Orbi will work.
