Reply
Orbi - WPS process in process
cornishrex
Hi, I've just bought my orbi kit. It won't let me switch on beamcast and mimu. It tells me that a wps process is in process and I should try again later. But it constantly says this every time I have tried. I found a solution to the problem for other routers by pressing the WPS button for 30 seconds. But that solution does not work for the orbi (having pressed the sync button for 30 seconds).
can anyone help? I've searched for an orbi specific solution but cannot find one...
many thanks
Message 1 of 4
Accepted Solutions
cornishrex
Re: Orbi - WPS process in process
I'm sorry. I went back and checked again after your post and this time it worked. It definitely wasn't working earlier today. I can't explain it. Sorry to have wasted your time.
Message 4 of 4
All Replies
so have you got the orbi router and sats connected and the lights have gone out indicating along the way they have a good signal to each other , eg blue light b4 it switches of the light , as until this happens the wps is actually still working
Message 2 of 4
cornishrex
Hi, yes indeed. I've had it all up and running for 36 hours now. Had the blue light. Genie or the web page reports a good link between the two boxes. Any thoughts ?
Message 3 of 4
cornishrex
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 5631 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 6E
