- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
- « Previous
- Next »
Orbi: We really need separate SSID for 2.4 Ghz and 5Ghz or speed is limited to less than 200 Mbps
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Re: Orbi: We really need separate SSID for 2.4 Ghz and 5Ghz or speed is limited to less than 200 Mbp
@Retired_Member,
If you follow the steps I provided in this other thread, you can create separate SSIDs for your 5 GHz and 2.4 GHz networks. At the very least that will allow you to troubleshoot your issue and see if it is related to that or not. I don't suspect it is, but if you're technically inclined, it's easy enough to try and revert if it doesn't help:
How to set a separate SSID for the 5 GHz network on your Orbi
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Hello all,
I have the Orbi bundle from Costco and have found that the single SSID approach is not working with half of the devices I have at home.
The newer devices (laptops and phones) connect just fine and I have great coverage.
However, some of the my older laptops when trying to connect are just returning an error "cannot connect to this network". This is after providing the correct password.
Does anyone know if there is a way (for the layman) around this without having to buy new laptops?
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
@st_shaw is spot on. I wrote up a post that describes How to set a separate SSID for the 5 GHz network on your Orbi.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
If there is no way to increase speed beyond 300+ mbps in orbi 5g then $400 is not worth it.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
You need a high-end very capable WiFi device to get top speed. I get an average of 470 Mbps with an iPhone 7+ when connected to the Orbi router, and 380 Mbps when connected to the satellite. That's about as good as it's going to get.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
@Moh_V It wasn't clear from what you wrote. If you can get 300 Mbps on that phone with the Verizon router then you should do better than 92 Mbs with Orbi. Something must be wrong. I have a couple questions:
1. Is your verizon rotuer's WiFi still active? You should turn it OFF.
2. Is Orbi in Access Point mode? You should put Orbi in Access Point mode if you are still using your Verizon router.
3. You said you disabled 2 GHz. How exactly did you do that? The latest Orbi firmware does not allow disabling bands.
4. Check your cabling and connections to make sure Orbi is connected through to your router using gigabit hardware and cat5e or better cables. A speed limit of 92 Mbs sounds like Orbi could be limited by a 100 Mbps LAN connection somewhere.
5. What do you get for a speed test if you wire a computer to the Orbi router?
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
If you're taking bets, my money is on #4.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
- « Previous
- Next »
