- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Orbi: Why do I have to factory reset to get Attached Devices to show?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Firmeware version: V2.5.1.8
For some reason, every month or so, my Orbi loses the ability to show attached devices.
And then it is factory reset time.
Why? What's going on?
This super sucks as I'm past being able to return this and I'm tired of having to enter the names of all my devices everytime I have to reset.
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
So I didn't end up factory resetting the router. It just seemed like such a drag to figure out which device was which and reenter names for them.
Saturday and Sunday the attached devices list still said 0 satellites, 0 attached devices.
This morning I was about to bite the bullet and factory reset, but got distracted with something else.
This after I was going back to it, when lo and behold, the attached devices list started working again.
Still on V2.5.1.8
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Orbi: Why do I have to factory reset to get Attached Devices to show?
V2.5.1.8 is BAD
get rid of it
- Mark as New
- Bookmark
- Subscribe
- Permalink
What is good?
And is downgrading possible?
- Mark as New
- Bookmark
- Subscribe
- Permalink
@lokimon wrote:
What is good?
go to the dowload area and enter your model number
I'm running RBR50 (Orbi Router) Firmware Version 2.3.5.30 since Oct 2019
@lokimon
- Mark as New
- Bookmark
- Subscribe
- Permalink
Still on V2.5.1.8
- Mark as New
- Bookmark
- Subscribe
- Permalink
Glad it's working. Please mark your thread as solved so others will know.
Please do a backup configuration to file for safe keeping. Helps save time if a reset is needed in the future.
Enjoy.
@lokimon wrote:So I didn't end up factory resetting the router. It just seemed like such a drag to figure out which device was which and reenter names for them.
Still on V2.5.1.8
- Mark as New
- Bookmark
- Subscribe
- Permalink
But how would I know if the settings were or were not causing the issues. 🙂
- Mark as New
- Bookmark
- Subscribe
- Permalink
If you hadn't done a reset since last FW update, possible prior residual configurations from last FW version may have become incompatile with newer FW. Sometimes NG makes changes to FW which can cause problems with prior configurations. NG did change the way or how they handle device detection on v2.5.1.8. Sometimes users don't see problems and some do. I tend to reset after each FW update and setup from scratch to avoid problems seen with just applying FW upates and continuing operation. This ensures a good installation of FW and a configuration. I'll then safe off a new backup configuration to file for safe keeping. Saves time if a reset is needed.
- Mark as New
- Bookmark
- Subscribe
- Permalink
@lokimon wrote:But how would I know if the settings were or were not causing the issues. 🙂
Factory reset is for lost passwords
encouraging factory resets after updates is making excuses for BAD firmware
