Orbi WiFi 7 RBE973
Reply
Orbi WiFi - Poor wireless speeds
emstevens44
Follower
Just setup my new Orbi Wifi System. I have AT&T Uverse with Gigapower to the house. The residential gateway for Uverse is the Pace 5268AC. I have disabled the wireless on the router and set the router to pass through the Orbi via DMZ + so the Orbi acts as a router with a public address.  My issue is when I connect to it via wireless I have extremly slow down and upload speeds. I have tested multiple devices and all have the same issue. If I patch my laptop directly into the Orbi Router I am able to get 300+ down and 800+ up. When connected wirelessly I am only getting 20 down and 40ish up.
Anyone have this issue and have any information that might be useful.
Thanks.
Model: Orbi High-Performance AC3000 Tri-Band WiFi System (RBK50)
Message 1 of 2
DarrenM
Sr. NETGEAR Moderator
Re: Orbi WiFi - Poor wireless speeds
Hello emstevens44
I would factory reset your orbi and make sure it is on the latest firmware. you also may want to try changing the wireless channel see if that helps.
DarrenM
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 2336 views
  • 1 kudo
  • 2 in conversation
Announcements
Orbi WiFi 7
