Orbi WiFi 7 RBE973
Reply
Orbi WiFi Slow Nvidia Shield
Syngensmyth
I get 200 MG down with my laptop but only 10-20 down with Nvidia Shield in the same room. I have not yet been able to hook to ethernet yet to verify those speeds. I am closer to the base router than the satellite and connected at 5g. It is usable for streaming but the reduced speed is curious.
Model: RBR50|Orbi AC3000 Tri-band WiFi Router
Message 1 of 3
Accepted Solutions
Blanca_O
NETGEAR Moderator
Re: Orbi WiFi Slow Nvidia Shield
Hi @Syngensmyth
Welcome to NETGEAR Community!
If laptop is getting the expected speed then router should be fine. Kindly check if NVIDIA Shield has an update available. Was this working before?
Blanca
Community Team
Message 2 of 3
All Replies
Blanca_O
NETGEAR Moderator
Hi @Syngensmyth
Blanca
Community Team
Message 2 of 3
Syngensmyth
Thanks. Shield updates automatically. I have found some router settings to try for when I get back to that location. Considering adding MoCA. Very happy with Orbi in all other cases.
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 2616 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
