Orbi WiFi 7 RBE973
Reply
Orbi WiFi System
jimv64
Follower
Orbi WiFi System
will the orbi system be nbn compatible?
Message 1 of 2
Re: Orbi WiFi System
hi
the term NBN is specific to australia i believe , eg its called just fiber in other countries or vdsl , depending on what type of NBN you have
fttn is where the internet still uses the phone line and connects to whats called vdsl
fttp is where the tech comes in and installes whats called a NTD in your house and you connect ethernet to it
and there are a few other types called fixed wireless and sat and hfc all known as NBN in OZ
so the orbi can connect to
fttp direct ( if home phone isnt needed )
fttn needs a vdsl modem and then you can connect the orbi behind it
for more info on aussie NBN you should go to the australian broadband forun called whirlpool forums
https://forums.whirlpool.net.au/
and specifically the orbi thread
NETGEAR Introduces Orbi Wi-Fi Mesh system
https://forums.whirlpool.net.au/forum-replies.cfm?t=2559904
pete
as many factors errect australian broadband and the many ways it connects
pete
btw you will find me on the modem / router section of whirlpool forum , i just dont want to confuse these forums with the connectivity specific to australia
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 4229 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
