Reply
Orbi WiFi System
peltolivier
Follower
Orbi WiFi System
hi,
I want to install my orbi but i have a router and modem in 1 so do I need to buy a separate modem or not?
Model: Orbi High-Performance AC3000 Tri-Band WiFi System (RBK50)
Message 1 of 2
Re: Orbi WiFi System
hi
it depends on how you want to run it all and how your internet is connected
you can ether bridge the modem/ router you have so it works as a modem only and connect the orbi system behind it running as a router and connecting to the isp
or
leave the modem / router as it is and connect the orbi behind it and run the orbi system in ap mode
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 1633 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 6E
