- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Orbi WiFi System
- Mark as New
- Bookmark
- Subscribe
- Permalink
Orbi WiFi System
Hi guys.
I'm thinking of buying an orbi wifi system. Can I use it with the Technicolor TG784n v3 Gateway installed by my Internet provider?
I would appreciate any advice you can give me.
Thanks.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Orbi WiFi System
Hello Leumam
Yes you can either bridge the gateway to be a modem only or you can run Orbi as a Access point.
DarrenM
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi Darren. Thanks for the reply.
What´s the difference between the two?
Should I turn off the wifi on the technicolor gateway?
Thanks.
Leimam.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hello Leimam
That would be the best option is to make the Technicolor in modem only mode.
DarrenM
- Mark as New
- Bookmark
- Subscribe
- Permalink
Leimam wrote:Technicolor TG784n v3 Gateway
hi
if your on some form of dsl
the technicolor modems are usually not that easy to bridge and even if it can be bridged your isp may not allow pppoe connectivity which would be needed for the orbi to run in router modem behind the bridge technicolor
so
if you can sucessfully bridge the technicolor and your isp allows pppoe connectivity you can then use the orbi router in its full mode
or if no bridge
as suggested you could use the orbi in AP mode and the orbi then works like wireless access points and the technicolor would work as normal and be the modem and router and just have its wifi disabled
what country and isp are you with
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi.
I'm from Portugal and my isp is Meo.
I have since learned that I don't have root user privileges on the Technicolor router and can only shut down Wi-Fi. I'm going to see if it's possible for them to remotely bridge the device.
Thanks for the help.
