Orbi WiFi 7 RBE973
Reply
Orbi WiFi System
Palmyren
Follower
Orbi WiFi System
Hi, I have a 4G wifi router at a cabin where there is no cabled internet connection available. Can you connect a orbi mesh router (with a satellite) directly to the 4G routers so that the Orbi works as just an ap and the 4G router is the gateway? The 4G router is a Tp-link Archer MR200.
Model: Orbi High-Performance AC3000 Tri-Band WiFi System (RBK50)
Message 1 of 2
Accepted Solutions
cinek
Apprentice
Re: Orbi WiFi System
you can configure orbi to be in AP mode and it;ll work with your existing router
https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point
Message 2 of 2
All Replies
cinek
Apprentice
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 847 views
  • 1 kudo
  • 2 in conversation
Announcements
Orbi WiFi 7
