- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Orbi WiFi System
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi All,
I am interested in buying netgear orbi wifi system to install in my new house in singapore a hdb 4 room flat with a 93 square feet, there are different model and type. Need some advise like what model should i get? do I need to buy a twin pack or 3 pack in order to enjoy a full coverage at home? Thank you.
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
For that kind of size of home, a single router only or a Orbi router only should be sufficient:
https://www.netgear.com/support/product/orbi.aspx
The main router base can cover up to around 2000sq feet by itself, depending upon building matierals.
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Orbi WiFi System
Hi Furry,
As what you suggest is using just one single orbi router is enough, i don't need any additional satellites correct?
Do i need to place the router at the center of the house or anywhere of the house corner to enjoy the full coverage?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Yes and placement on the main floor and center of the home is preferred.
