- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Orbi Wifi Satellite Has a Solid White Light On Top. RBS50
- Mark as New
- Bookmark
- Subscribe
- Permalink
I purchased the Orbi with the 2 RBS50 satellites. Everything was working fine until I moved one of the satellites from one room to another and now it will not reconnect. The light on the top is constantly white. I tried to re-sync and even hit the reset button, but nothing has worked so far. Does anyone have a solution?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Orbi Wifi Satellite Has a Solid White Light On Top. RBS50
Did you hold the reset button in for about 6 or 7 seconds until the green power light flashed amber?
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Are you using a paper clip in the tiny reset hole?
With the unit powered on, insert the paper clip until you here the little internal button click.
Hold it in for a few seconds until the green power light starts flashing amber, then release.
That will do a full factory reset.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Yes, I am using a paperclip and I do hear a click. I hold it for at least a minute, but the light never changes from solid green.
- Mark as New
- Bookmark
- Subscribe
- Permalink
That's odd. I recently did the exact same reset procedure.
Move the RBS50 closer to the RBR50 then try and power cycle the RBS50 to see if it will reconnect.
If you have not factory reset it then it you should not have to resync after moving the satellite to another location.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I tried to move it closer and do the reset procedures found in the manual. It doesn't respond any different. The satellite does not respond to anything. It just stays solid white on top and a solid green LED on the back.
When I try to do the reset after powering it on, nothing happens.
Can it be plugged in via usb or ethernet for a reset or diagnostic?
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hello Brye
are you able to plug a Ethernet into the unit and then find the default gateway of the unit then try to log into that unit. If you can log in try to re flash the firmware if you can not I would contact support as @Streak2 suggested.
DarrenM
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi BRye,
I'm having the exact same problem. Did you manage to fix your issue somehow? It would be great if you could share any solution you had.
Thank you very much!
Jeremy
- Mark as New
- Bookmark
- Subscribe
- Permalink
Jeremy,
When you log into your orbi system http://orbilogin.com/ is it not seeing the RBS50?
How many satellites is it reporting?
If it's not seeing the satellite then have you tried to resync or reset/resync?
https://kb.netgear.com/31018/How-do-I-sync-my-Orbi-router-and-satellite
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi Streak2,
I have two satellites, but only one is connecting. The other just sits there with the solid white ring LED on.
I've now gone through a support case and it was determined that the unit was faulty and it will be replaced by Netgear.
Best regards and thanks for your time!
