- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Orbi Wifi
- Mark as New
- Bookmark
- Subscribe
- Permalink
Orbi Wifi
We have the Orbi Wifi running in our home, model RBR20 with 2 satellites. Everything works really well (streaming services, cell phones), except that my husband can't connect to WiFi using his brand new new Dell laptop running Windows 10. Orbi shows up as an available network but the WiFi connection is not stable. We went through troubleshooting, but nothing changed. I have no problems connecting to WiFi via Orbi on my Acer running Windows 10. Any ideas?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Orbi Wifi
If one laptop is working and the other isn't, it maybe the wireless adapter card in the one effected laptop...
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials when wirelessly connected.
What WPA security modes are you using?
Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Orbi Wifi
@LRF wrote:my husband can't connect to WiFi using his brand new new Dell laptop running Windows 10. Orbi shows up as an available network but the WiFi connection is not stable....... Any ideas?
Does this new laptop connect to other WiFi networks? and the connection is stable? Eliminate the laptop as the problem before tackling the Orbi.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Orbi Wifi
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Orbi Wifi
Well, darn. It's never the easy answer. How about more description of the symptoms. Is there a pattern to the problem? Like a certain number of minutes before the connection drops? Does the connection ever restore by itself? If he does a "disconnect" and then a "connect" on the Dell, does it connect again? What does the Orbi say about the connection (under Attached Devices, or by selecting the Dell on the Orbi app)?
