Reply
Orbi - Wired Backhaul Setup
SanjB
I have the below setup
Orbi Router connected to a Non Managed GigaBit Switch. My 2 satellites are connected to the GigaBit switch.
Should I be using the Orbi Router in Router Mode or just as a Satellite?
Can I then use devices off the Orbi ethernet ports and Gigabit switch ports?
Model: RBR50|Orbi AC3000 Tri-band WiFi Router
Message 1 of 4
ekhalil
Master
Re: Orbi - Wired Backhaul Setup
1. Operating Orbi in Router or AP mode depends on how you set your ISP modem/router.
To have Orbi in AP mode, the ISP modem has to have router functionality and act as the network router, otherwise Orbi should be in Router mode.
2. Is the switch connected in Orbi Router ’s WAN port or one of the LAN ports?
My Setup Internet Fiber ONT 250↓/250↑ISP Telenor | Wifi Router Orbi RBR850 + RBS850 + RBS750, AP Mode, Wired/Wireless Backhaul / Orbi RBR50 + 6x RBS50, Router Mode, Wired/Wireless Backhaul | Switches Netgear GS208Time Zone CET (Sweden)
Message 2 of 4
SanjB
My ISP modem can also act as a router. Currently it is running as a Modem and the Orbi as a router. (Connected to the Orbi via WAN port)
I have intermittent problems with streaming 4k, HD.
My switch is connected to the Orbi LAN port.
Message 3 of 4
ekhalil
Master
Then please keep Orbi in Router Mode
@SanjB wrote:
........I have intermittent problems with streaming 4k, HD.
This is probably because of an issue in latest Orbi SW packages. Please follow the instructions in this post as a wororkaround: https://community.netgear.com/t5/Orbi/Wired-Backhaul-in-recent-firmware-releases/td-p/1780008
Ok, then yes, you can connect other wired devices to the same switch if you want to.
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 584 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 6E
