Reply
Orbi and Arlo Pro 2 Camera
TropicalDoc
Initiate
I have the Orbi router with 3 Satellites connected.  I purchased the Arlo Pro Wireless Camera system and have 5 cameras hooked up to it.  My question is :
Is there a way to hook the Arlo Base station into the entire Orbi network so the cameras run off the wifi, not just off the base station.  I tried attaching the base station to a satellite with an ethernet connection, now I have the base station hooked directly into the Orbi router with an ethernet cable.  I have cameras in an area that has excellent wifi reception, but is too far from the base station to get a good signal.
Thank You
Model: RBR50| Orbi AC3000 Tri-band WiFi (Router Only)
Message 1 of 5
Guru
Re: Orbi and Arlo Pro 2 Camera
@DarrenM
@Christian_R
My Setup (Cable 1Gbps/50Mbps)>CAX80 v2.1.2.1(LAG Disabled)>RBK853 v4.6.3.16(AP) & RBK752 v4.6.5.14
Additional NG HW: C7800/CM1100/CM1200CM2000, Orbi CBK40, CBR750, RBK50(v22), SXR30(v110), R7000(v34), R7800(v84), R7960P(v82), EX7500/EX7700, XR450(v120) and WNHDE111
Message 2 of 5
Christian_R
NETGEAR Employee Retired
Hi @TropicalDoc
Thank you for reaching out to the community for suggestions. Unfortunately, this configuration would not work. However, if most of your cameras capture good Wi-Fi in an area where one of your satellites is set up, you may want to connect your Arlo base station to that satellite.
For other configurations from other Arlo community members, I suggest you look into the Arlo Community:
https://community.arlo.com/t5/Arlo-Smart-Home-Security/ct-p/Arlo
~Christian
Message 3 of 5
TropicalDoc
Initiate
Can I purchase a second base station or Netgear wifi extender to add range to the current syste?.  Unfortunately all my cameras cannot be captured by the wifi of just one satellite. Cost is not an problem, I just want to solve the issue.
Thank you
Message 4 of 5
Christian_R
Hello @TropicalDoc
Yes, you may use a second base station to extend the range of your cameras as mentioned in this Arlo thread.
https://community.arlo.com/t5/Arlo-Pro/Two-base-stations/td-p/1282848
~Christian
Message 5 of 5
Top Contributors
Discussion stats
  • 4 replies
  • 6614 views
  • 3 kudos
  • 3 in conversation
Announcements
Orbi WiFi 6E
