Orbi WiFi 7 RBE973
Reply
Orbi and Bose Soundtouch
Guytech
Apprentice
Since the last software update to  V1.9.1.12 I have issues controlling my Bose WiFi systems. If the device is connected to a satellite, I cannot control it with a device connected through the router and vice versa. Switching beamforming and MU-MIMO on or off did not change it. Switching satellites off so that only the router works resolves it. Very frustrated...
Model: Orbi High-Performance AC3000 Tri-Band WiFi System (RBK50)
Message 1 of 3
DarrenM
Sr. NETGEAR Moderator
Re: Orbi and Bose Soundtouch
Hello guytech
so anytime a unit is connected to a satellite you can not control it?
DarrenM
Message 2 of 3
Guytech
Apprentice
Hi Darren
Yes, you are correct. At startup the Bose app keeps restarting at 3-4 second intervals. I tried several different things. I eventually deleted the Bose apps on my computers and reinstalled it. Up to now this seems to have resolved the problem. I cannot explain why it seems that  the software update changed it's functionality.
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 3425 views
  • 3 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
