Orbi WiFi 7 RBE973
Reply
Orbi and Cneturylink Fiber
yammahaw
Follower
Current configuration:
Internet - 1 GB symetrical Fiber Internet
Network equipment: Orbi RBK53
ONT > ORBI System
Issue
I have an orbi system in my house and the issues I am experiencing is I have to constantly restart the system due to download and upload speeds being less than optimal. Currently on 5gHZ band I am getting like 100 down and 40 up. The speeds are slightly better when I run the speed test through the orbi system itself but no where near the 1 GB speeds. Has anyone else experienced this?
Model: RBK53|Orbi AC3000 Tri-band WiFi System
Message 1 of 2
Guru
Re: Orbi and Cneturylink Fiber
What is the Mfr and model# of the ISP ONT the NG router is connected too?
Armor, Circle, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 328 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
