Reply
Orbi and Draytek issue
mdroyle
Luminary
I have used the Orbi in AP mode v succesfully with BT Smarthub and also a Netgear modem. I now want to use a Draytek 2862 for the routing with Orbi still in AP mode. But when I introduce the Draytek the Orbi flashes magenta and I can't see it on the network - although I can see the satellite and other devices, and I can connect to the internet. So I can't administer the Orbi and unsure if devices can connect to it directly via wifi.
I assume there is a setting onthe Draytek that isn't correct but all views and insights welcome.
Model: RBR50|Orbi AC3000 Tri-band WiFi Router
Message 1 of 3
Guru
Re: Orbi and Draytek issue
Try a power OFF of both new modem and Orbi for 30 seconds then back on.
When in AP mode the Orbi RBR should get a IP address from the modem. Should setup the same way as the other modems.
Try a factory reset on the RBR and setup from scratch and configure AP mode. Do other devices connected to the modem get an IP address?
My Setup ISP SparkLight | Internet Cable 1000↓/50↑ CM1200 Modem |  Wifi Router Orbi RBK853 (Router Mode), Wired Backhaul and R8000 | Switches NG GS105/8, GS308v3, GS110MX and XS505M |
Additional NG HW: C7800/CAX80/CM1100/CM1200/CM2000, Orbi: CBK40, CBK752, RBK50, RBK853, RBK752, RBK953, SXK30 | NightHawk: R7000, R7800, R7960P, R8000, R8500, RAXE500, RAX50, XR450, EX7500/EX7700
Message 2 of 3
Guru
Any progress on this?
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 624 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 6E
