Orbi WiFi 7 RBE973
Reply
Orbi and FEIT 2.4GHz IoT wi-fi bulbs
Knight21024
Guide
I'm trying to connect to my FEIT IoT wifi bulb using my iPhone.  FEIT requires connection over 2.4GHz but I'm unable to connect my iPhone to the 2.4GHz because i'm unable to find or set or configure a 2.4GHz SSID on my ORBI router.  Has anyone been able to setup FEIT wifi bulbs?
Model: RBK53| Orbi Router + 2 Satellites Orbi WiFi System
Message 1 of 6
Accepted Solutions
Knight21024
Guide
Re: Orbi and FEIT 2.4GHz IoT wi-fi bulbs
Ok after reading a lot I decided to try setting the power on the 5GHz for ORBI to 25%.  I then went to the ORBI admin website http://192.168.1.1 and viewd the devices - found my iPhone and saw it was connected on 2.4GHz vs 5GHz.  This allowed me to configure the FEIT electric 2.4GHz wifi bulbs.  After I was done setting up all the blubs I put the 5GHz back to full power 100%.
Message 3 of 6
All Replies
Guru
The Orbi combines the 2.4Ghz and 5Ghz into 1 SSID. The orbi automatically handles which radio devices get connected to based on the device design and support. Orbi doesn't support separating SSIDs between the radios.
Message 2 of 6
Knight21024
Guide
Message 3 of 6
Guru
Enjoy. Smiley Wink
Message 4 of 6
Jamesmc12081969
How does one set the power on the 5ghz for orbi to 25% to achive these results enabling me to use the FGEIT 2.4GHz Wifi Bulbs?
Model: RBK22| Orbi AC2200 Tri-band WiFi System
Message 5 of 6
Guru
Advanced Tab/Advanced Settings/Wireless Settings
Message 6 of 6
Top Contributors
Discussion stats
  • 5 replies
  • 16372 views
  • 5 kudos
  • 3 in conversation
Announcements
Orbi WiFi 7
