Reply
Orbi and Nighthawk X4 WiFi Range Extender
farshad
Follower
Hello Community
Can anybody tell me if it would be possible to add a Nighthawk X4 WiFi Range Extender to an Orbi satellaetie AC3000 two pack network?
Currently, I am using the Orbi system in point of access mode.
Appreciated
Model: RBK50| Orbi AC3000 High-Performance Tri-Band WiFi System
Message 1 of 2
Guru
Re: Orbi and Nighthawk X4 WiFi Range Extender
Currently no. The extender works with having two wireless SSID names coming from a wireless router with out using any Smart Connect. Orbi uses smart connected to combine two wireless SSID names into one. If you need more extenders, get the Orbi Satellite extenders for use with the Orbi router.
My Setup (Cable 1Gbps/50Mbps)>CAX80 v2.1.2.1(LAG Disabled)>RBK853 v4.6.3.16(AP) & RBK752 v4.6.5.14
Additional NG HW: C7800/CM1100/CM1200CM2000, Orbi CBK40, CBR750, RBK50(v22), SXR30(v110), R7000(v34), R7800(v84), R7960P(v82), EX7500/EX7700, XR450(v120) and WNHDE111
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 2040 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 6E
