- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Orbi and Sky Muster (Aus)
- Mark as New
- Bookmark
- Subscribe
- Permalink
Quick query, does anyone know if Orbi works with NBN Sky Muster satellite internet modems.
Am looking at replacing current set up of router and access points with Orbi
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
I don't see a reason why not!.
Please see the following article for more information: https://kb.netgear.com/236/Configuring-your-NETGEAR-router-for-satellite-connection
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Orbi and Sky Muster (Aus)
If you have Modem Combo Units:
This would be a double NAT condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
1. Configure the modem for transparent bridge mode. Then use the Orbi router in router mode. You'll need to contact the ISP for help and information in regards to the modem being bridged correctly.
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
@Jacoba wrote:Quick query, does anyone know if Orbi works with NBN Sky Muster satellite internet modems.
