Reply
Orbi and hardwired connections
Shofam
Follower
Since I only have one ethernet port on my Orbi router (my older router had 4) how do I connect my Hue hub, my Arlo hub and my samsung Smarthings hub? Would a splitter work?  Any thoughts?
TIA
Message 1 of 2
Guru
Re: Orbi and hardwired connections
You can always attach an external Non managed, non green ethernet Gb LAN switch to the back of the RBR and then connect other LAN devices to this switch. They make them starting with 5 ports, 8, 16, 24, 48 ports models. There inexpensive as well.
Example:
https://www.netgear.com/support/product/GS108.aspx
My Setup Internet Cable 1000↓/50↑ CAX80 Mode Mode | ISP SparkLight | Wifi Router Orbi CBR752 v4.6.7.7(Gateway Mode), Wired BackhaulSwitches Netgear GS105/8 |
Additional NG HW: C7800/CM1100/CM1200/CM2000, Orbi CBK40, CBR750, RBK953(v6.0.3.68) & XR450(v130), RBK853 v4.6.7.5(AP) & RBK752 v4.6.7.5, RBK50(v23), SXK30(v110), R7000(v34), R7800(v84), R7960P(v84), RAXE500(v78), EX7500/EX7700, GS308v3 and WNHDE111
Testing
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 284 views
  • 1 kudo
  • 2 in conversation
Announcements
Orbi WiFi 6E
