- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Orbi and satilite go offline daily
WiFi Connection goes off daily. I need to reboot it via app to get it back online. Please help!
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Re: Orbi and satilite go offline daily
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials.
MIMO, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
If you updated to recent FW v.210, try enabling Daisy Chain. Some have mentioned that this seems to be working in reverse order, enabling means disabled actually.
My Setup (Cable 900Mbps/50Mbps)>CM1100>Orbi RBK50 and Orbi RBK852
Additional NG HW: C7800/CM1100/CM1200, Orbi CBK40, Orbi RBK852, R7800, R7960P, EX7500/EX7700, XR450 and WNHDE111
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
What model Orbi do you have?
What FW is currently loaded?
Is the Orbi system operating in Router or AP mode?
What WPA security modes are you using?
Try enabling Beamforming and MIMO. Under Advanced Tab/Advanced Settings/Wireless Settings
@duanemusser wrote:
I have had a similar problem. My orbi was great for about 95 days. now, i have to reboot it daily. My Asus would do this automatically. It is annoying and frustrating.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Hi @duanemusser
Do you have the latest firmware (v2.3.0.32) installed? If not, please update the firmware and let us know of the result.
Blanca
Community Team
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
I do have the latest firmware.
As far as the previous suggestions, my signal inside is fine. It keeps dropping connection to the internet. My fiber modem is working fine.
Unless my ISP started enforcing DHCP expiration, I don't know what else would case it to stop connecting.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
@duanemusser wrote:
Blanca,
I do have the latest firmware..
I always question when people say this without specifying an actual version number.
My Equipment: Cox Cable (350Mb/35Mb), Orbi AX6000 (RBR850, RBS850), w/2 x RBS50) (Wired backhaul), NG GS116PP Gigabit Smart Switch, Synology DS1019+ NAS
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
I also noticed that RBR40 is not in the options above. Am I on the correct forum?
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Yes.
You can try the new FW update to see if it helps you out:
You need to load the satellite first to v32, download v212 to the RBR40 first, then upgrade to v28. Manualy download the files and manually upgrade the FW using the RBRs UI. I would factory reset and setup from scratch both units after FW has been upgraded.
@duanemusser wrote:
I looked again and I have FW V2.2.1.210. The firmware check says it is the latest version available.
