- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Orbi app miss some things
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Orbi app miss some things
Hillie79:
I also have an Android phone. Also have the RBR50/RBS50 router. The Speedtest shows in the bottom right hand corner of the Orbi app. I would suggest trying to scroll on your phone to see it. The Guest WiFi shows in the bottom left hand corner of the Orbi app. Again, try scrolling in the app to see it. Both options show on the screen in my phone, so hopefully you just have a smaller phone that requires scrolling.
BillYoung
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hillie79:
Sorry to hear that. Let's go over a few things, like what do you see on your Orbi app screen.
When I open the Orbi app, I see the following. The top half of the screen shows the Orbi router, the Internet status, and the number of Satellites. The bottom half of the screen shows four buttons: WiFi Settings, Device List, Guest WiFi, and Speed Test.
It should be noted that I am using Orbi app version 1.5.14.
How about you? What does the app show when it is open, and what version of the app are you using?
BillYoung
- Mark as New
- Bookmark
- Subscribe
- Permalink
Further, on the top of the app I have the same as you.
Below I have Wifi settings, device list and support. That's all
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hillie79:
OK, I got what you got on your screen in the app. But only after trying to access the Support option from the drop-down menu. And when I got out of the app and back into it again, it showed me what I told you again.
So, have you accessed the Support option in the app, and then not closed the app? I would do that, and see what it shows you.
BillYoung
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hillie79:
Firmware version: 1.12.0.18 on both the router and my satellite.
I really believe this is more about the app than the router firmware, though.
BillYoung
- Mark as New
- Bookmark
- Subscribe
- Permalink
Maybe someone from Netgear can help me
