Orbi WiFi 7 RBE973
Reply
Orbi app won't login if admin password contains ;
bs6mjb
Tutor
Netgear Mods
Orbi app won't login if admin password contains ; (in my case the ; was at the end of the password)
The password is fine for the web interface but Orbi app fails. Might want to fix that in a future release.
Matt
Message 1 of 3
Re: Orbi app won't login if admin password contains ;
in general you should never use non common characters in ether user names / passwords , ssid's or passphrases
stick to just lower and upper case and numbers
Message 2 of 3
bs6mjb
Tutor
Sure....but my point was that if the regular web interface allows you to set and use the password then the Orbi app should allow the password to be used as well.
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 2590 views
  • 2 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
