- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Orbi as Airties4920 replacement
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi community,
I am currently looking for a replacement mesh from my provider supplied Airties4920.
I am using the airties to use the LAN port for an Android box that have no AC wifi capability, and the cabled Airties4920 does.
I am however not satisfied with the quality of the wifi blanket it makes, and am looking at the RBK50 as possible replacement.
My question is if it is possible to attach a LAN cable to the sattelites and get dhcp supplied IP this way, or if it is only possible to connect using wifi?
Thanks in advance.
Br Michael
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Orbi as Airties4920 replacement
Yes, the Orbi supports attaching devices through the satellite ethernet and gives you great speed doing that. You cannot however attach a satellite through ethernet to the router yet - as it does not support ethernet backhaul in this firmware release - perhaps in the future.
- Mark as New
- Bookmark
- Subscribe
- Permalink
My intention is not to attach satellites via cable, but solely to rely on a good wireless connection. The Airties seem very limited in its range, and I am very close to returning them to my internet provider. Currently it seems that the 5Ghz channel/mesh has lost connection and even Netflix has problems getting data.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Depending on what you mean by limited in range - The Orbi has a great connection to it's satellites thru 5Ghz band, but you know that is a limited range band. Generally you will want your satellites to be 50 feet or less from your router unless there is no walls in which case you can probably get a higher range. Currently my satellites sit about 25 & 40 feet form the router and I have no issues. The 40 ft on the same floor and the 25 ft on another floor through radiant heat flooring.
