- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Orbi b locks access to wireless heating controls
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have recently set up a mesh system replacing a TP link solution. Unfortunately the Obi system blocks access to my siemens RDS110 heating controls. The device logs on to the network, no problem, but the app on my phone says it is off line. Any clues would be helpful
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Orbi b locks access to wireless heating controls
what modem/gateway is the router connected to?
Is the Siemens showing up in the attached devices list?
What firmware is on the orbi and satellites?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi The Orbi Is Connected to A Draytek Router. I Can See The Siemens Device In the DHCP table on The Draytek.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Should uld Have Added Firmwarevv2.7.3.22
- Mark as New
- Bookmark
- Subscribe
- Permalink
Is the orbi being ran in access point mode?
Or do you have the orbi's IP address entered into the Draytek's dmz?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi It Is Running In Ap Mode. I Have No Idea Every Word Is Starting With A Capital !
- Mark as New
- Bookmark
- Subscribe
- Permalink
In access point mode, the dreytek is controlling everything. And if its showing up in the dhcp table its connecting back to the primary router. so I'd be looking at your dreytek for whats blocking the setup.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi It's Not The Draytek As I Have Been running A TP Link System In Exactly The Same Way Before I Replaced It With The Orbi. In Fact I Am Running Them In Parallel Through The Draytek At the Moment As That Is The Only Way I Can Use The Controller Remotely At The Moment
- Mark as New
- Bookmark
- Subscribe
- Permalink
running them in parallel?
meaning both orbi and draytek in router mode
Or orbi and tplink?
If you're using the draktek in router mode, why not simply connect the heater to it?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi The Dratek Runs The Connections For The Office Vpn. I Currently Have Two Wireless Networks Running Off It. TP Link And Orbi. If I Connect The Siemens To The TP Link Everything Works If I Connect To The Orbi It Does Not
- Mark as New
- Bookmark
- Subscribe
- Permalink
Is the tplink in access point mode as well?
Or just the orbi?
If you put the orbi in router mode and put its ip address into the draktek's DMZ, does it work then?
- Mark as New
- Bookmark
- Subscribe
- Permalink
@oxoclear wrote:Hi The Dratek Runs The Connections For The Office Vpn. I Currently Have Two Wireless Networks Running Off It. TP Link And Orbi. If I Connect The Siemens To The TP Link Everything Works If I Connect To The Orbi It Does Not
According to the RDS110 user guide, the app displays Offline if:
The thermostat is not connected to the cloud server. Several reasons may result in disconnection:
The thermostat is powered off.
The thermostat is not connected to the Internet.
So your phone app isn't trying to talk directly to the RDS110 but instead they're communicating through the shared cloud server. If your RDS110 and phone both have access to the Internet then it should not be Offline.
- Does your phone have internet access when connected to the Orbi wireless?
- Does your RDS110 display indicate that it is connected to the internet?
- You mention your Dratek runs the office VPN. Did you have to do anything special with the TPLink to get the RDS110 connected to the internet over this VPN? If yes, do you need to do the same with the Orbi?
- There is a special Administrated WLAN option that "discover the networks nearby". Are using this option instead of Private WLAN? If so, maybe you need to run this option again on the RDS110 to discover the new Orbi network and allow access.
- Is your RDS110 connected wirelessly to your network? If yes, did you change it to connect to the new Orbi SSID?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi , if I put the Orbi in router mode I am unable to access the shared office drives on the network ?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Does it work directly connected to the draytek?
- Mark as New
- Bookmark
- Subscribe
- Permalink
