- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Orbi backhual connection attempt
- Mark as New
- Bookmark
- Subscribe
- Permalink
I am generally OK with my Orbi it works alright, minor quirk but ok.
I have a NAS connect to a Netgear R7000 which act as a bridge to the Main orbi wifi. It works but since the bridge is using the fronthaul it limit the speed. In attempt to access the backhual, which I know is almost impossible from what everyone said, but this is my attempt, maybe other could built on it.
I enable telnet on the Orbi, log in the router
I ran the command "nvram show" which contains tons of info, including settings and suchs
but I found 2 setting to my interests
wla_2nd_ap_bh_ssid=NETGEAR_ORBI_hidden(2 digit number I redacted this for now)
wla_2nd_ap_bh_wpa2_psk= (a very long string of number and letter, looks like encrypted txt, but I don't think so I think it is the key itself, I could be wrong, I try to decrypt this but obiously didn't have any luck)
I tried to use these setting to connect using my labtop and log the event.
The final event that I log is
Connection failed. Interface = Intel(R) Dual Band Wireless-AC 7260, Reason code = 0x38002. (according to what I found about the code is driver disconnected while associating)
From what I reason is that the key is right, the network name is right, but it Netgear is using something maybe nonstandard so normal client couldn't connect, I hope someone could continue this work. Administrator, please allow us to connect to backhaul, I don't ask for this as a full blow feature, just make it so that advance user could, I would love to use my R7000 as a direct bridge to the backhual.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Orbi backhual connection attempt
Use a cable instead. Wireless where wireless belongs - to mobile devices. But not to connect a NAS.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Do you have a satellite in place as well? You can connect the NAS to the satellite and see if this does anything.
Try factory resetting the R7000 and set it up from scratch.
What FW is on the R7000?
What FW is on the Orbi router?
- Mark as New
- Bookmark
- Subscribe
- Permalink
What I am after is using another router to bridge to the Orbi backhual. Effectively turning it into a satellite sort of. Just for fun and understanding. The R7000 run latest netgear firmware and also tried ddwrt as well. Won't connect. I think next I will try to clone the Mac address of one of the Orbi satellite to see if that work.
- Mark as New
- Bookmark
- Subscribe
- Permalink
And your using the wireless bridge mode on the R7000? Possible there is an issue with wireless bridge and Orbi systems. However I have my older WNDE111 wireless bridge connected to my 1 satellite that services my mom in laws DISH Joey in her room next door to where the Satellite is. Possible there is a configuration or FW issue with the R7000.
What FW are you using on the Orbi router?
- Mark as New
- Bookmark
- Subscribe
- Permalink
I am essentially trying to hack the system to make any router with a bridge mode to act as a satellite, which I am sure Netgear will not approve of, because they will loose money on selling satellite. But I am trying to do this for fun.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Ok man. Just asking.
Good Luck.
