- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Orbi blocking websites when i connected to Altice 1 modem
- Mark as New
- Bookmark
- Subscribe
- Permalink
I recently connceted my Orbi to the Optium Altice 1 Modem and after that i am restricted to websites. I have certain functions such as email and can access certain apps on my phone. Please help?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Orbi blocking websites when i connected to Altice 1 modem
Whats the Mfr and model# of the ISP modem? Built in router here by chance?
- Mark as New
- Bookmark
- Subscribe
- Permalink
not sure the model number but it has built in modem and router...even when I plugged it back into the Verizon internet Orbi had the same issue which it never had before.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Modem Combo Units:
Couple of options to try,
1. Configure the modem for transparent bridge mode. Then use the Orbi router in router mode.
2. If you can't bridge the modem, disable ALL wifi radios on the modem, configure the modems DMZ for the IP address the Orbi router gets from the modem. Then you can use the Orbi router in Router mode.
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, LAN to LAN and configure AP mode on the Orbi router.
- Mark as New
- Bookmark
- Subscribe
- Permalink
thank i will try those.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Let us know how it goes...
- Mark as New
- Bookmark
- Subscribe
- Permalink
And word on results?
I fought the good fight with Altice.... there new system... (stuck with it till Fios rools around to my part of Bronx)
Their hardwar communicate to each other via the wifi, so i can not be disabled. Also come to find out I am also one of the new hot spots for them as welll. All in the fine print folks....
At the end of the day their Wifi is terrible Just terrible. Thw wired Lan off the Main box is great. The satellite boxes is garbage. and they would allow you to bridge their router.
I will run through your list tonight and report back any successes or failures.
I really miss my Orbi. I worked it just worked no effort.
Bronxjl
