Orbi WiFi 7 RBE973
Reply
Orbi cannot reach my outbuilding - what should I do
PaulATeixeira
Follower
Hello i have a RBK50 the wireless signal does not reach my out building what product do you sell that will help me
Model: RBK53|Orbi AC3000 Tri-band WiFi System
Message 1 of 3
CrimpOn
Guru
Re: wifi
If the outbuilding is small and relatively close to the house, Netgear makes an "outdoor" Orbi satellite.  If the distance is large, then a different approach is needed.  So, what kind of outbuilding?  How far from the house?  How close is an Orbi inside the house to the wall closest to the outbuilding?
Message 2 of 3
Guru
Re: wifi
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials when wirelessly connected.
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 720 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 7
