Orbi WiFi 7 RBE973
Reply
Orbi choosing wireless backhaul when wired is available?
ArthurP
I have the Orbi router and two satellites running wired into a TP link switch.  But the satellites connect to the router over the wireless backhaul.  The satellites use the wired connection to connect to each other but not the router! The third satellite is only wireless, as it should be.
My intuition is that the wired connection would always be preferred because it is more reliable, higher bandwidth and faster(?).  Is something wrong here or is this normal behavior? Thanks.E4040494-EB65-427A-969E-D8CC54432ED1.png
Model: RBR50|Orbi AC3000 Tri-band WiFi Router, RBS50Y|High Performance AC3000 Outdoor WiFi Mesh Extender and Add-on Satellite
Message 1 of 6
Accepted Solutions
CrimpOn
Guru
Re: Orbi choosing wireless backhaul when wired is available?
Unfortunately, Netgearis forum software package does not allow others to view images that are placed "in-line" using the Photos icon in the menu bar until the images are approved by a forum moderator. There are not many moderators, so this can take hours (or days). Images "attached" using the Browse button in the lower left of the edit panel appear immediately.
  • Which specific TP-Link switch is being used?
  • Orbi routers expect satellites to appear on LAN ports, not on the WAN port, so it is important that the switch is connected to an Orbi LAN port ('behind' the Orbi) rather than between the Orbi and the ISP modem.
Message 2 of 6
All Replies
CrimpOn
Guru
Message 2 of 6
ArthurP
Thanks.  I'm using the ‎TP-Link TL-SG1016PE 16 port POE router.  I have not done any management, just plug and go.  I have moved the satellite cables from the swtich to the router but I had to leave before I could check the status.  I'll report what I find when I go back
Message 3 of 6
CrimpOn
Guru
Oh, my.  The TP-Link TL-SG1016PE is far from a dumb switch.
https://www.tp-link.com/us/business-networking/easy-smart-switch/tl-sg1016pe/#specifications
PoE, VLAN's, IGMP Snooping,
Will be interesting to hear how it goes.
Message 4 of 6
ArthurP
Connecting the satellites to the Orbi itself rather than the switch did the trick Thanks!
Message 5 of 6
Guru
NG GS-105/108v4, D-Link DGS-105/108 and HP ProCurve 1400/1800 series switches work for Orbi systems.
Message 6 of 6
Top Contributors
Discussion stats
  • 5 replies
  • 1654 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 7
