Reply
Orbi connection to Xfinity modem router
Hirgs
I purchased an Orbi and 2 satellite package from Costco and am connecting to Xfinity modem/router combo.  Am I better off bridging the xfinity modem router and setting the Orbi up as the main router, or should I leave the xfinity router on and set up Orbi as an Acess Point. What are the benefits to each approach?
Model: Orbi High-Performance AC3000 Tri-Band WiFi System (RBK50)
Message 1 of 3
DarrenM
Sr. NETGEAR Moderator
Re: Orbi connection to Xfinity modem router
Hello Hirgs
I would suggest bridging the Comcast modem and make orbi the main router so you have 1 wifi network and less wifi interference.
DarrenM
Message 2 of 3
there is no real benefits as such its just a matter of which device is used as the router and controls everything
bridging the Xfinity turns it into a transparent bridge between the isp and the orbi behind it ( note your isp must ether use pppoe or ipoe as if they only use pppoa it wont work ) , the orbi then does all the routing and wifi
leaving the Xfinity in router mode and setting the orbi to ap mode means the Xfinity does all the routing and you just turn off its wifi and the orbi just does wifi
so decide which has the better routing functionality and use it
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 8148 views
  • 0 kudos
  • 3 in conversation
Announcements
