- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Orbi disconnecting from modem when I turn on my TV and tivo
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Any thoughts??
Thanks in advance
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Re: Orbi disconnecting from modem when I turn on my TV and tivo
Hello MacFan22
That is odd that 1 device crashes the system you could try and reset the IP address of the TV and tivo see if that stops it from happening. You can find the address reservation in the LAN settings of the orbi.
DarrenM
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Try the following:
1. Set a static IP address for your Orbi (if the IP is currently 192.168.0.3, just set it for that and take DHCP out of the mix); and
2. Go into your Spectrum DOCSIS Modem and set a DMZ for the Orbi.
See if that resolves the issue.
I have seen the DHCP-counter get confused with the Orbi--I set mine as a static when I had that issue (albeit on an earlier firmware).
.mws.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
+1 from my side
I had my primary orbi turning magenta ( lost of connectivity with adsl router : internet provider)
My internet provider router was also rebooting randomly sevral times per day, it was not having such behavior before Orbi was plugged in my network.
After assigning a static ip to Orbi primary router, and affecting on internet router the same static IP lease for it based on orbi mac adress, i do not have any issue at all.
internet router is not rebooting anymore and orbi connectivity to internet is stable.
