Orbi WiFi 7 RBE973
Reply
Orbi doesn't work with Chromecast. Please help
Xrayphoton13
I just received my Orbi Rbk50 today. I got it set up and it updated to the latest firmware. My phone, ring doorbell, and Google home all connected fine and seem to be working but my Chromecast ver. 2 will not work. It says "Reconnect me. You are connected to the network but can not access the internet." I tried restarting the modem and Orbi and the Chromecast. I tried factory resetting the Chromecast several times. Is this a known issue? Any ideas? Thanks
Model: RBK50| Orbi AC3000 High-Performance Tri-Band WiFi System
Message 1 of 4
Accepted Solutions
Guru
Re: Orbi doesn't work with Chromecast. Please help
What FW is currently loaded?
Try WPA instead of WPA2, then try WPA and AES Only.
MIMO, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
If you updated to recent FW v.210, try enabling Daisy Chain. Some have mentioned that this seems to be working in reverse order, enabling means disabled actually. So try this out as well.
https://community.netgear.com/t5/Orbi/Firmware-2-2-1-210-and-connection-problems-Skybell/m-p/1649275...
Message 2 of 4
All Replies
Guru
Message 2 of 4
Xrayphoton13
Thank you! I found out my Google home also did not have internet internet access. Man I was bummed out but in the end I only had to make one of your changes to get everything to work right. I'm on firmware ver. 2.2.1.210 and daisychain was on by default. Once I turned that off everything instantly started working!
Thank you!
Message 3 of 4
Guru
Glad it fixed it. Enjoy.
Smiley Wink
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 19620 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
