Orbi WiFi 7 RBE973
Reply
Orbi doesn't work with Chromecast. Please help
ReneBaars
Follower
Earlier I saw someone with the same problem with in my opinion a very complex solution. However this discussion is closed right now, so that,s why I am opening a new discusssion to share my solution.
I had the same problem connecting Chromecast to Orbi. I could not connect it wireless. What I then did was connecting wired direclty to my Orbi satellite and I could install in without any problem. After that I looked what would happen after disconnecting the cable and.... Orbi remembered the wired settings and now Chromecast work fine with Orbi wireless. After that I have done this the same way with my other Chronmecasts and it work perfectly. So in this way you can fool Orbi with succes. Good luck.
Message 1 of 2
Guru
Re: Orbi doesn't work with Chromecast. Please help
Thanks for sharing.
Possible this forum thread?
https://community.netgear.com/t5/Orbi/RBR50-Issue-connecting-to-chromecast/m-p/1969207#M101782
Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 510 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
