Orbi WiFi 7 RBE973
Reply
Orbi downliad speed is capped/throttling
Mannaee
If I'm using the orbi as main router I get the max speed from ISP, 500 Mb download and 50 Mb upload. But when I use it as access point my download speed capped at 100. Tryed almost everything and nothing worked. Cables are cat 6 and I tried factory rest.
Please help because I need to use my asus router as main router RT-ac8u.
Message 1 of 2
Guru
Re: Orbi downliad speed is capped/throttling
What FW is currently loaded?
Is the Orbi system operating in Router or AP mode?
If you need to use a different router as your main host router, then I recommend you configure the Orbi system for AP mode:
https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 1451 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
