Reply
Orbi dropping internet connection when outside - RBK50
slefkoff
Luminary
Hi all - I have the RBK50 system at my house and love it. However, I have a weird issue - when I walk outside, I lose internet connection almost immediately. Devices (me - iphone x, wife - iphone 😎 showing full wifi signal, but websites don't load, apps don't load, etc. When I'm inside, everything works. When I step one foot outside, I still get full wifi but no internet. Any thoughts? Why would internet drop once we walk outside despite having full signal connection to the router/satellite?
Model: RBK50| Orbi AC3000 High-Performance Tri-Band WiFi System
Message 1 of 6
Guru
Re: Orbi dropping internet connection when outside - RBK50
Is Fast Roaming enabled? Try disabling this under Advanced tab/Advanced/Wireless settings. Disable MIMO and Daisy Chain as well.
Try setting manual channel 1, 6 or 11.
What is the distance between you and the router or satellite when your out side?
What is the distance between the router and satellite(s)?  Feet?
How big is your home? SqFt?
My Setup ISP SparkLight | Internet Cable 1000↓/50↑ CM1200 Modem |  Wifi Router Orbi RBK752 (Router Mode), Wired Backhaul and R8500 with Orbi RBKE963 (AP Mode), | Switches NG GS105/8, GS308v3, GS110MX and XS505M |
Additional NG HW: C7800/CAX80/CM1100/CM1200/CM2000, Orbi: CBK40, CBK752, RBK50, RBK853, RBK752, RBK953, SXK30 | NightHawk: R7000, R7800, R7960P, R8000, R8500, RAXE500, RAX50, XR450, EX7500/EX7700
Message 2 of 6
slefkoff
Luminary
Thanks for the quick response. I'll try the suggestions tonight when I get home.
Distance between me and router when outside - Maybe 60-70 feet? Literally inside the door the internet works, when I step outside 3-5 feet from the door it doesn't. No drop in WiFi, just drop internet.
Distance between router and satellite - Satellite is 1 floor up and the other side of the house, so maybe 85-100 feet or so.
Home is about 3000 sq. ft. on 2 floors. Has unfinished 3rd floor that would add another 500 sq. ft. or so.
Message 3 of 6
Guru
Whats the signal quality report for the 80-100ft distance satllite? wireless connected? Seems it might be a bit too far for this one satellite from the router. Starting should be 30 feet, and maybe up to around 50-60 feet depending on building materals...
Ya, you should have signal outside. I set up my friends RBS50 systems a couple of weeks ago. One router and one satellite. I put his satellite up stairs and it's wired back haul connected as the signal was POOR connected wirelessly.  Hes got a thick house. I was amazed that I still had full bars on my phone out side in my car right before I left. I was at least 30 feet from the satellite and router.
https://community.netgear.com/t5/Orbi/Orbi-firmware-update-v2-1-4-16-availability/m-p/1592753/highli...
Message 4 of 6
slefkoff
Luminary
I think I have it wired back to the router, but I'll have to check that tonight to confirm. If not, I'll check the signal strength and move it if it is poor. I guess it is possible that I'm connecting to the satellite when I step outside (full WiFi signal) but the satellite isn't catching any internet from the router, right?
Message 5 of 6
Guru
Ya, you'll need to check to see if the satellite has internet access and thruput...you can check whats connected to the satellite via it's IP address. Has a connected clients list there too. Something you can look at and help you out. Ya you'll need to test with something connect to the satellite. If something is getting internet close to the satellite or in same room, then you can rule out the satellite and internet there...
Message 6 of 6
Top Contributors
Discussion stats
  • 5 replies
  • 989 views
  • 3 kudos
  • 2 in conversation
Announcements
Orbi WiFi 6E
