- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Orbi ethernet backhaul
- Mark as New
- Bookmark
- Subscribe
- Permalink
Does the new Firmware version update 2.1.1.16 allow the satellites to be connected to the router via Ethernet Cables to boost signal strength?
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Orbi ethernet backhaul
- Mark as New
- Bookmark
- Subscribe
- Permalink
Yes, just plug in the network cable between the router and the satalite. It should switch from wireless backhaul to wired after a bit.
Having said that, the whole system is very unstable at the moment. You will get frequent disconnects. With wired backhaul it seems to disconnect lot more then with wireless backhaul.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thanks. I have a 6100 sq ft home - a walkout two story. My modem is annoyingly in my basement, so the router is down there as well, but the builder did have the wherewithall to run an ethernet cable from the basement to the first floor and from the basement to the second floor. I put a satellite on my first floor and a satellite on the second floor, but the connection has cut out three times in the past week in my office (on second floor in the corner of the house). I downloaded the new firmware and connected the second floor satellite to the cable running up from the router and speed has increased from about 5 to about 15mbps. Any other thoughts as to what I might do to improve reliability?
- Mark as New
- Bookmark
- Subscribe
- Permalink
There is a major firmware stability issue with the ORBI router right now. So nothing you can do but hope Negear will release a fix for it.
See the thread for the Beta Download -
https://community.netgear.com/t5/Orbi/OrbiOS-2-1-1/td-p/1476960/jump-to/first-unread-message
- Mark as New
- Bookmark
- Subscribe
- Permalink
Are the satellites connected directly to the RBR50? Or are they all connected via a switch? I had a lot of trouble with the satellites not being recognized until I the ethernet runs to the satellites directly to the RBR50. Probably not an issue for most, but caused me lot of hassle/fiddling.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Mine are wired straight to the RBR50. The only switch I'm using is on the first floor where my smart TV, Xbox One, and DirecTV box are sitting. I have all of those hard wired to a switch, which is plugged into the RBR50. With speeds approaching 100mbps on my first floor (my Spectrum limit), I didn't see a reason to plug in the RBS50 there. It's the second floor that was having issues, and so far so good on connecting that to the RBR50 with the new firmware.
