Orbi WiFi 7 RBE973
Reply
Orbi factory reset itself after update
davispw
Initiate
MY ORBI FACTORY-RESET ITSELF WHILE AUTO-UPDATING TO 1.12.0.18 LAST NIGHT!
What a pain to wake up to this morning. Anyone else?
Message 1 of 5
MandMBlahnik
Re: Orbi factory reset itself after update
Same thing happened to my Orbi last night.  Yoohoo, Netgear, you should take a look at the update you're pushing.
Message 2 of 5
zloy
same thing happened last night, the router (RBR50) reset itself after upgrading to 1.12.0.18 firmware.
all settings are lost...
Model: Orbi High-Performance AC3000 Tri-Band WiFi System (RBK50)
Message 3 of 5
ShawnGlan
Me to. I am trying to reset my orbi wifi but my wifi is not recognizing orbi wifi so not able to reset.
Any solutions?
Netgear didnt do the right testing. Before releasing.
Message 4 of 5
DarrenM
Sr. NETGEAR Moderator
Hello shawnglan
Have you tried to connect with a wired device and go into the wifi settings and return them to what they use to be?
DarrenM
Message 5 of 5
Top Contributors
Discussion stats
  • 4 replies
  • 3516 views
  • 0 kudos
  • 5 in conversation
Announcements
Orbi WiFi 7
