- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Orbi firmware corrupted during update
- Mark as New
- Bookmark
- Subscribe
- Permalink
Orbi app on iPhone showed a firmware update was available, so I initiated update from Orbi app. Router now appears bricked. After update attempt, the power light was flashing red (corrupted firmware). Now, after a few power cycles, it has a steady green power light and LED router ring remains flashing white (booting up). It stays stuck in the boot-up stage. I've tried using paperclip on reset button, but power light stays solid green no matter how long I depress the reset button, and the LED router ring continues to flash white.
Any suggestions on what to do??
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Orbi firmware corrupted during update
You can give this a try:
https://kb.netgear.com/22688/How-to-upload-firmware-to-a-NETGEAR-router-using-TFTP
Use the TFTP program thats built into windows, do NOT use the on stated in the link. It doesn't work. The one built in with windows does.
You'll need a LAN wired PC connected with the router.
IF this fails, you'll need to contact NG support and ask for an RMA.
I recommend doing any FW updates with a LAN wired PC connected to the router.
- Mark as New
- Bookmark
- Subscribe
- Permalink
The same thing happened to me. Last Netgear device I ever buy. What do us lowly Mac users do?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Have you tried the recovery process to see if you can get the unit back in operation? Ask a neighbor, friend or family member with a Winodws PC to barrow or help you with. Mac has TFTP programs available too I believe. Myabe even built in to OSX.
If not, you should try it, or contact NG support and ask for an RMA...Nothing else we can do for you here in the forums.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thanks - This page has good instructions for Windows users: https://kb.netgear.com/000059633/How-to-upload-firmware-to-a-NETGEAR-router-using-TFTP-client - It is left as an exercise for MacOS users to translate the instructions to Mac. Eventually, I figured it out. Requires some Ethernet config work in the Network control panel, and then tftp in the Terminal to send the downloaded file.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Glad you got it working.
Enjoy.
