- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Orbi firmware update v2.1.4.16 availability
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Orbi firmware update v2.1.4.16 availability
Replacing my Orbi with Unifi... doing it right now.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Using v2.1.4.16 since the day it has been available here with zero issues.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I had the same issue and i couldnt figure it out. My set up was the orbi router to a 8 port switch to the satilite. I then connected the router directly to satilite and instantly fixed my issues. Do you have anything in between the 2 devices?
- Mark as New
- Bookmark
- Subscribe
- Permalink
There are issues with managed swtiches, Non manged switches work well with Orbi systes. Managed not so much. One user posted that he found that disabling IGMP Protocols on his manages switch helped get Orbi working with his managed switch. You can try this if you have a managed switch. I have two non manged switches in between my Orbi and satellite. Zero issues.
Also your PfSence maybe a factor as well. Your putting a Firewall in front of another firewall build in to the Orbi. Try conneting the Orbi router directly to the ISP modem and see. If your using a Firewall appliance or another DCHP router in between the Orbi and modem, then either put the Orbi router in a DMZ or configure the Orbi router for AP mode. No need for double NAT on a network.
Seems like this is a over complicated configuration which maybe causing your problems. Simplify first to see what happens.
I just get on my friends RBK50 yesterday. Working so far with just being connneted to his modem.
@Site wrote:
It's the Orbi. I have worked on internet tech for 20+ years.
But for the sake of answering; I am using a motorola mb8600 modem attached to gigabit comcast ethernet. modem is in bridge mode. The modem is routed through a pfsense box that is attached into a gigabit switch; the orbi is attached into the same gigabit switch. A windows domain controller provides dhcp for the house; and the orbi is set to a reserved address; all routing information is correctly specified. The internet has never failed when the orbi loses connection - I often would VPN into the house just to remotely reboot the router (now my family has the app to do it). I have an old basic wifi router also in AP mode that only reaches one room and is slow; but has never failed every time the orbi has failed. The wifi radios on the orbi including through the satellites are working fine even when it can't connect to the internet. - I can always connect to the orbi via a wifi connected device (regardless of whether the device are connected to the main hub or any satellite) or from within the house via a wired connection. About once every day or so; all wireless devices through the orbi lose access to the internet. The app always states the internet is offline; the orbi web interface always claims its online (whether the internet works or not). Rebooting it always corrects the issue. I am running the latest firmware but have never had a stable system (previous firmware went about a week before starting to frequently fail). We are streaming more as we go into the summer so its possible the orbi can't handle traffic load.
At this point; I just need a reliable system and am curious what people have replaced their orbi with.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Make sure your switch is a non managed switches. Managed switches seem to give problems with Orbi systems. Also make sure your LAN cabling is good in between the router, switch and satellite. CAT6 recommended.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I wanted to provide some performance testing results for the latest firmware. I honestly don't know if these are good because I don't know what expectations I should have over Wi-Fi.
Setup:
The server is a Windows 10 PC running xjperf 2.0.2 wired into a RBS50 Satellite running 2.1.4.16 firmware.
The client is a Windows 10 laptop running the same version of xjperf, but is wireless to the same satellite.
I first performed an internet speed test from the wired PC:
The results are consistent with what I am paying for from internet provider (200Mbps/5Mbps).
I then setup xjperf to transfer a 1GB file from the client to the server and ran the test three times. Please note that both devices are running NMVe M.2 storage devices so storage read/write times are not a limiting factor in this test. This was the result from LAN speed test:
In 3 tests, the file took between 22-25 seconds to transfer and you can see the thruput on the graph above. Again, I don't know if this what I should expect from two devices connected to the same satellite, one wired, one wireless. I just wanted to provide some feedback.
Overall, the connection has been fairly stable. I had to reboot the router once when devices would refuse to connect to certain websites. I verified that DNS was working properly by running nslookup from the affected devices, but then they would timeout attempting to load data. Rebooting the router fixed the issue and the connection has been good for a day again.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Orbi is in AP mode and not acting as a DHCP server or anything - and should not be acting as a firewall or NAT (at least I would hope - if it is always an active firewall even in AP mode than I definitely need to return it). The only firewall active firewall and NAT should be direclty through pfsense.
I do have a managed switch. I will move the Orbi from being wired into the switch to be wired in between the router and the switch.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Will have to wait for your pics to get approved.
Whats the Mfr and model# of the ISP modem your using?
For DNS, have you tried using 1.1.1.1 and 9.9.9.9 for DNS on the Router?
Setup:
- Mark as New
- Bookmark
- Subscribe
- Permalink
Ok making sure.
Yes, seen others with problems with managed switches and Orbi systems. Try putting the Orbi router behind the PfSense and test with out the switch. Check with the user manual or Mfr of the switch to see if there is anything regarding IGMP protocol that you can disable to test. Check your PfSense as well for anything IGMP that could be effecting Orbi. Might try the Orbi in router mode behind the Modem directly if you can. Might find a non managed switch to test with as well. They work for me.
- Mark as New
- Bookmark
- Subscribe
- Permalink
My cable modem is a Hitron CGNM-2252 with the resedential gateway function disabled. The Orbi is performing all the routing, dhcp, etc. For DNS, I am using the OpenDNS servers.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Ok, just checking. Those modem router combo can effect connected routers.
Sounds like it should be working well then...
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Seen others with problems using this RBW30 extender. Not sure why however this one model seems to not work well with the orbi system. I would try to see if you can get another RBS50 some place and see if adding this results is something different.
How big is your home? Sq Ft?
What is the distance between the orbi router and the RBS50?
@thossessess wrote:
Update to my prior issue where my Nest Cams stopped working post this update. I removed the Wall Satellite RBW30 from the account and no more issues. All Nest Cams are working perfectly. Issue is the Wall Satellite causing connectivity issues with my Nest Cams. The RBR50 and RBS50 do not appear to be impacted. What stinks now is that I’m down an access point, but now my Nest Cams are working again. Why would this cause a problem?
- Mark as New
- Bookmark
- Subscribe
- Permalink
For those of you who are interested in trying something different. I went with a Unifi system. Thanks to Amazon I got everything I needed in just a day. 1 - Cloud Key, 1 - 8 port POE switch, 1 - Unifi Security Gateway, 1 - Outdoor UAP-AC-M-Pro, 1 - UAP-AC-HD (for my family room where we need the best wifi), 1 UAP-AC-LR (Long Range Access Point).
$1000 all in.
My Orbi setup was 1 Router, 3 satellites, 1 outdoor satelite. - $850 all in.
I did not have to use my dumb switch I had to buy because my smart switch was not compatible. Hopefully I can return the switch I bought.
With only 3 access points vs 5 with Orbi...
The results are amazing. Took me all of 1 hour to get everything setup and configured. Blazing fast everywhere in my house and most importatly outdoor.
I have not seen my wemo switches load this fast on my iphone, my Sonos players all work as smooth as ever - no more issues where I can't find a player or "xyz" music service not working. I was able to go all the way to my boat dock and stay connected and control everything on my network. That is at least 300 feet from the outdoor access point.
We use unifi in our office - I should have known better.
The web gui on unifi is amazing. I don't want to get banned here so I will leave it at that.
I am a happy camper now. Anyone want my orbi setup - just PM me.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I don't know much about this stuff, I just want this product to work. I don't need any special features, just solid wifi across the whole house and my HomeKit stuff to work. For me and my iPhone X, everything works great, never had a problem. For my shared HomeKit access (my girlfriends iPhone X), she constantly has issues connecting remotely to the HomePod hub. I went back to 2.1.4.10 and it fixed the issues for a week, now it has come back. Any suggestions?
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
I tried to click on the link for the RBR50 and RBS50 firmware to download then manually update the Orbi. It states "requested file does not exist, Please enter the file information requested, file code (blank box)" How can I update manually when I can't find the most recent firmware 2.1.4.16? Please point me in the right direction.
Thank You
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
You'll need to go to the support site and manually download the v.10 version of the FW thats posted there. Once you install it, your router may see the v.16 in the Check for FW updates in the UI. If they haven't removed v.16 from there update servers. Its how i got my friends Orbi set up the other day:
No complaints from him.
Thank You
- Mark as New
- Bookmark
- Subscribe
- Permalink
Did you install through the user interface updating both router and satellite at same time? The orbi downloaded the firmware 2.1.4.16 automatically. I haven't installed it yet.. Things have been working well w/ the 2.1.4.10 firmware. Thanks for your feedback.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I manually installed the FW to the satellite first while it was connected. Then upgraded the router. Upgrading the satellite seems to be the best method to ensure it's upgraded first and gets reconnected. Seems that if the satellite doesn't get upgraded first, there maybe issues of its reconnection. After both were upgraded to v.10, I then used the routers FW web page to check for updates, it saw v.16 for both the router and satellite. I use the UI to update both to the v.16.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Is a new Beta Firmware coming ? Tired of "hand cranking" with paperclip this Orbi sattalite everytime power goes out like hand cranking 1920s cars!
- Mark as New
- Bookmark
- Subscribe
- Permalink
That's what UPS's are for...avoiding effects of power outages on electronic equipement. I have my cable modem and routers on them. They come in all sizes and are very helpful for things that you want to stay on during a short power outage. And protection from surges, brownouts, etc.
Just a thought.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Okay bad news/good news. I checked my primary 24 port TP-Link managed switch and IGMP was NOT enabled by default, so my inability to connect my wired backhaul through this was not my problem, as suggested in this forum. But the good news is I did have another 16 port DLink switch connected which I went through to the Orbi satellite and when I replaced that with another: BINGO! My wired backhaul started to working and showed up in the web interface as expected. All this with firmware 2.1.4.16. Nice.
I have started to ID all of my 83 IP connected devices, so I can see what is connecting and where, but so far things are looking good.
All I can say is with all the networking devices and configurations out there, it looks like it's not all on the Netgear engineers for firmware issues, from my perspective. At least in my situation. Hope this information can help some of those that have not tried additional solutions.
