- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Orbi firmware update v2.1.4.16 availability
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Orbi firmware update v2.1.4.16 availability
@cheshbr wrote:
I have an Orbi RBK50 system running in AP mode on FW v2.1.4.16 in perfect working order, using a wired backhaul with all devices connecting to their nearest Orbi device in 5Ghz mode if it’s capable of 5Ghz, or 2.4Ghz where that’s all they allow, eg Lifx globes only function on a 2.4Ghz network. Ever since FW v2.1.4.16 has been available, I have used it without any issues whatsoever. Apple HomeKit works, LIFX works, TP-Link and Wemo switches work perfectly, Apple HomePod, Amazon dot and Google Home all just work, as do assorted iPhones, iPads and Macs, and the devices of visiting family and friends.
So I repeat, what problem? What needs to be fixed?
Could it be that those of you who have less than satisfactory experience with Orbi should have another look at their skill levels, their configuration, their internet source, or other devices and peripherals that may be interacting poorly? Perhaps they assume that Orbis are simple to set up. They are not.
There is a need for basic network knowledge and fundamental skills, eg understanding IP addresses, MAC addresses, DHCP, reserved IP addresses, etc. Orbis are not Plug n Play. And there’s a need for ongoing maintenance to keep everything working optimally.
Try running your system NOT in AP mode, and see if you experience issues. I have had nothing but problems with this system, even after RMAing a satellite, there are times where devices connect, but the only way to get the system working is to unplug the satellite and plug it back in, or reboot the system. I don't know whether there are routing issues or not, but there is still something wrong with the firmware or the devices themselves.
It looks like you are running yours in AP mode and have no issues. I have 27 devices on the network, and running wireless backhaul on the satellite. I'm going to try running this thing in AP mode, as I just ordered a Ubiquiti ER-X. I hope that fixes all of my issues. Time will tell.
- Mark as New
- Bookmark
- Subscribe
- Permalink
My freinds 50 series is working well, in router mode though. No complaints.
@CyberExorcist wrote:Try running your system NOT in AP mode, and see if you experience issues. I have had nothing but problems with this system, even after RMAing a satellite, there are times where devices connect, but the only way to get the system working is to unplug the satellite and plug it back in, or reboot the system. I don't know whether there are routing issues or not, but there is still something wrong with the firmware or the devices themselves.
- Mark as New
- Bookmark
- Subscribe
- Permalink
No, I can’t run my Orbis in router mode because I have a basic DSL service requiring a modem, and mine, a Billion 7800VDOX modem/router, handles the routing. I mearly disabled WiFi, hooked up the Orbis in AP mode and experienced a great outcome first time (although the wired backhaul fought me at first). I bought Netgear Orbi for its mesh and coverage functions, and when I do get some new high speed broadband (yes folks, we here in Australia are being dragged kickin’ and screamin’ into the 21st century with new fibre infrustructure to be made available across the nation by 2020) I may try the Orbis in router mode as I won’t need the Billion. I could still use the Billion as a router only, but it’s a bit dated, and I too like the sound of the Ubiquiti Edgerouter X. I’d love hear about your experience with it. Good luck.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I recommend using the DMZ on your ISP router, which ever one you get for the Orbi if you want to run it in router mode if your ISP modem can't be bridged...
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thanks, but i’m Happy with my AP setup. And despite your suggestion of running dual routers and DMZ, I don’t want to make my relatively simple setup more complex, and you know my views on the danger of deploying DMZ permanently.
Once my broadband is up to scratch and I no longer need a modem, I will try my Orbi in router mode, or I could stay in AP mode and reconfigure the Billion to be just a router, or buy a Ubiquiti Edgerouter X. Others appear to be interested in the latter, too, so i’m Hoping they will keep us up to date with their experiences.
i do appreciate your advice and knowledge, and I think I have some value to add too. Isn’t that the purpose of a forum?
- Mark as New
- Bookmark
- Subscribe
- Permalink
I only mention DMZ if you have a modem that you can't bridge or still need to use as a main host router.
Again, don't discredit DMZ, it has a safe use when you have two routers on the line.
Of course. Also to educate as well.
- Mark as New
- Bookmark
- Subscribe
- Permalink
This is getting crazy, it's 2 hours i'm trying to get internet back in my house.
It all started when it prompted me to update to 2.1.4.16, i did it and hell broke loose.
I have Orbi in AP mode (router mode never worked), with one satellite via lan. Now the router is on the correct firmware, while satellite is on "2.1.4.16ww", whatever "ww" is, and i've been updating it for the third time. Each time it tells me "update successfull", and then asks me to update again from "2.1.4.16ww" to "2.1.4.16".
Bleah.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Have you downloaded the FW file and applied it directly to the satellite with a wire connected PC?
Bleah.
- Mark as New
- Bookmark
- Subscribe
- Permalink
So all issues have been resolved? No need for a new Beta then? I find that very odd.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
I can sense the frustration, I've had it too.
I think some improved updates on these moderated boards would go a long ways towards lowering the stress levels here.
I brought up the Apple homekit issue with them some months ago. I too had frustration opening a ticket as I wasn't going to pay an annual support fee to fix a problem created by Netgear. I pressed them through their twitter account and eventually got them to open a ticket when I pressed the matter.
From what I can see, the homekit issue has been resolved. The only other issue that's come up for me is the issue of the IPV6 having to be refreshed every two days or so in order to work. It is not an ISP problem from what I can tell (and I've actually tested this) - also others have the issue.
They opened up a second case for the IPV6 issue and and progress has been slow, admittedly but I have transmitted them captures of it when it is working and when it is not.
I am not having any other issues - I have a 150 / 15 connection - and an RBR50 with two RBS50 Satellites. I've got wired connections off one of the satellites (like my home office) as well as a couple of dozen wireless devices. iPhones, iPads, Apple TV, Chromebook, Windows computers, Apple computers, Android tablet, HP printer, homekit devices etc. There's also another router doing a double NAT for an alarm system. After the latest Chromebook update, it is no longer working in IPv6, but I think that might have been due to the Chromebook update. Other than that, and the aforementioned time out of the IPv6 operations, everything else is working for me.
I am not entirely happy about the situation, but I am not quite prepared to throw in the towel yet. I am helping with troubleshooting a couple of times a week and resetting the IPv6 every couple of days. What I am saying is it is liveable now...it wasn't before, with the Apple Homekit frustrations.
I am unable to recommend Orbi at this time (and I used to) but I am also not ready to throw it away and replace it.
I am using a version that is several numbers higher than 16, so they are working on versions....but at the same time, from my perspective, the version I'm using isn't any different than what 16 was...
- Mark as New
- Bookmark
- Subscribe
- Permalink
There is a limit to everything.. This useless Firmware has been Beta tested by us over a year now for $400 I would imagine by now after a year they would step up ...I am running out of bent paperclips and patience !!
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
What's the next gizmo they want us to Beta test for them for a year? I'm ready I have a pile of $400 in cash stacked up ready to set on fire..bring it on next useless Firmware device!
- Mark as New
- Bookmark
- Subscribe
- Permalink
It is unbelievable that you have to do this.
I and others are having none of the problems you appear to be experiencing. In 4 months of Orbi use I have never had to resort to using a paper clip, so unless yours are faulty, i wonder what other factors are at play here.
I run mine n AP mode, so my Orbi router is cable connected to another (primary) modem/router that connects to my ISP, and its WiFi is switched off. Thie primary router also handles DHCP, the table of which lists around 30 devices with reserved IP addresses. A cable from a lan port on the primary router connects to the yellow WAN port on the Orbi router. AP mode means your Orbis are passive WiFi distribution points only. Of course the success of your Orbis in this setup depend on the quality and configuration of the primary router.
There must be something that can be done to ease your pain
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
I've had the Orbi system for a year and a half, and have not once had to resort to a paper clip.
I have documented my one remaining issue, but something else is wrong if people are having to hit the reset button .....
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Cmol, about your paper clip regime, in an earlier post I made some suggestions. Did you look into them to see if they help? Why not try just a little harder?
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
You'll have a lot better time resolving orbi issues if the Orbi is the router and the AP. Mixing things up, especially discontinued routers, is an invitation for trouble.
- Mark as New
- Bookmark
- Subscribe
- Permalink
My experience differs. My Orbi system works better behind my Asus AC68U router. IMHO, the less your Orbi has to do, the more likely it is to succeed.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Cmol, now you are talking. An Apple AirPort Extreme is a capable, basic router, that has few extras beyond reserved IP addresses in DHCP. A family member has one on a pure fibre 100Mbps service, and it works ok for him in a modest sized house. One thing it does, though, is provide proof of concept - if it works then there’s nothing wrong with your ISP or internet connectivity.
I favour the Ubiquiti Edgerouter X too, but before you take that step, please consider the following...
- As you are in AP, the Airport is serving up IP addresses for the Orbi router and satellite(s). Do you know these IP addresses? Unless you reserve static IP addresses in the Airport DHCP for each Orbi, they will most likely change each time you restart them. Thereafter you can access the Orbi web interface using the reserved (fixed) IP address. Do you know how to do this? Check out my last paragraph below for more information
- Once you are in the Orbi router’s web interface you can change some of the settings under Advanced. How are these settings on your Orbi?
- Do you want to do a wired backhaul? If so, I discovered instant success by plugging the cable into the satellite first, then into the router, with both devices powered on. This happened so easily after many frustrated minutes of magenta ovals with the cables the other way round, ie, cable already connected to an Orbi router LAN port, then into the satellite. This always failed.
- Do you have the Netgear Genie app installed? This, and the Netgear Orbi app are valuable troubleshooting tools, particularly the device map which shows connect d devices, signal strength, etc.
If if you are an Apple user, download the Net Analyzer app, which connects to your WiFi network, and maps with tiny symbols the attributes of connected devices. Go to LAN, then scan, and look for an item with a small white “W” in a light blue box. Touch tat item, and on the next screen you will see “Web Interface. Yes” with a green dot. This will give you the IP address of your Satellite and Router, and if you touch it, it will open the web interface
good luck
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
1. Only the web app correctly shows connected devices, The Orbi phone app doesn't ever seen to show a full list of devices... Is there any way to fix this?
2. When I'm at the fringes of the 5ghz network using my phone , bandsteering switches between 2.4 and 5ghz, and this causes WiFi drop-outs. I'm guessing the only way to stop this is to go through that process that separates the SSIDs? Or does anything else help? If not, has there been any news on Netgear simplifying that process through the UI?
Many thanks for your help.
