- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Orbi firmware update v2.1.4.16 availability
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Orbi firmware update v2.1.4.16 availability
You can add a non managed swtich to the back of the router if you need additional LAN ports. Besure its a NON managed switch.
These work for me:
And use good quality LAN cable. CAT6 is recommended...
Review this:
@SDplinker wrote:
RBK23 only has 2 ports per device so there's no way to plug direct. RBK23 is fairly new I think (model is not in drop-down in the forums) - hoping for the best. It's a drag when my router is up on a cabinet upstairs and the satellites are dispersed - lots of trudging up and down. 🙂
- Mark as New
- Bookmark
- Subscribe
- Permalink
This firmware hosed my LAN. Please fix.
https://community.netgear.com/t5/Orbi/Orbi-firmware-update-v2-1-4-16-stopped-my-LAN/td-p/1594578
- Mark as New
- Bookmark
- Subscribe
- Permalink
How did it "hose" your LAN? More details please.
How is the system configured and set up? Placement?
Any switches in between the router and satellites?
Was a power OFF of the router and satellites for 1 minute after the FW was updated, then power ON the router and let it come to ready then power ON the satellites 1 at a time performed?
Last resort, try a full factory erase on the router and satellites then set up from scratch. Others reported that this helped them:
https://community.netgear.com/t5/Orbi/Orbi-MR-2-1-Update-3-23-18/m-p/1548414/highlight/true#M27868
https://community.netgear.com/t5/Orbi/speed-slows-down-Orbi/m-p/1551822/highlight/true#M28289
https://community.netgear.com/t5/Orbi/Is-2-1-3-4-in-auto-update/m-p/1553979/highlight/true#M28616
https://community.netgear.com/t5/Orbi/Orbi-Satellite-RBS50-Not-Connecting-via-Ethernet/m-p/1556692/h...
- Mark as New
- Bookmark
- Subscribe
- Permalink
I posted a link to more details. Here it is again: https://community.netgear.com/t5/Orbi/Orbi-firmware-update-v2-1-4-16-stopped-my-LAN/td-p/1594578
- Mark as New
- Bookmark
- Subscribe
- Permalink
That links to a different user. Please make a new post and share the details of your problem.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thanks for the replies! My "unmanaged switch" is my old router with the wifi turned off. Semi-managed switch?? LOL. Maybe there is still enough going on to cause problem. Regardless I plan to get an unmanaged 8 port becuase i'm maxed anyway. Just wanted to try out what I had. Appreciate the links to order of operations - will have a go.
Thanks
Casey
- Mark as New
- Bookmark
- Subscribe
- Permalink
Let us know how it goes when you get the non managed switch in.
Good Luck.
Thanks
Casey
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
That's fine, but the Orbi Pro forum doesn't have a thread announcing the v2.1.4.16 release as this one does. And, it appears there are some using the non-Pro version with the same issue. So it stands to reason that this might improve visibility to the issue.
- Mark as New
- Bookmark
- Subscribe
- Permalink
You can always start a thread of your own there as well. Yes, same base code I presume, however there are some differences.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I... did... did you not see the link I posted?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Seems like there working with you already.
Good Luck.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thanks Netgear. You almost convinced me that you had your stuff together.
But nope. You don't.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
This is the present layout of my Orbi system. I had a lot of connectivity issues with the release but it seems to be stable and performing well.
I moved “satellite G” to the first floor immediately below the router in the second floor. Also recently added a second wall satellite on the second floor.
I set the router to used a daisy chain topology and moved the router a few feet from a Phillips Hue hub. I susp3ct the Hue hub was the biggest issue.
Bottom line- I have good connectivity and performance now.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Politic's aside.
If the product was "fundamentally broken", it wouldn't work for anyone. That is simply not the case. YOU and a vocal minority of others on this forum may have SOME issues, but you do not represent ALL users.
I have been using the Orbi for 8 months now. Went thru two automatic firmware updates. Added a 2nd satellite. NO drama. It simply sits there and does it's job very well, no muss no fuss.
- Mark as New
- Bookmark
- Subscribe
- Permalink
@tsig wrote:
Politic's aside.
I don't disagree with you, but dismissing the amount of issues raised with tumerity is not beneficial either. There is clearly something wrong. I am an IT professional with over 20 years of experience and had a great deal of issues tracking down problems. For instance, my latest problem was a faulty satellite that was causing my whole system to crash. To Netgear's credit, they replaced the satellite out of warranty, but it took a long time to diagnose the problem.
I don't believe Netgear has performed an adequate amount of functional or regression testing when it comes to the plethora of networking hardware that consumers use. For you, it may be flawless, but you may be using a limited set of hardware that they have functionally confirmed. My ISP only supports TWO modems that support speeds over 200Mbs. I am essentially limited to a Hitron CGNM-2252. That's my only choice as of right now (unless I want to pay $300/mo for gigabit speeds), and there seems to be issues.
To solve the problem, I disabled the routing functions on the Orbi and am now using a Ubiquiti Edgerouter Lite to perform the routing functions as I have much more granular control over the routing functions and its interactions with both the Orbi and my modem. This is not an option for all users though so for someone who may not be an advanced user, they end up with an "at best" partially functional system.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Have you tried contacting them directly? A different approach might work.
- Mark as New
- Bookmark
- Subscribe
- Permalink
tsig, I agree with you in your response to Cmo1 about the vocal minority not representing us all, I too have an RBK50 system that just works and always has in the 4 months I have had them. Perhaps those having issues should satisfy themselves that their hardware and/or connectivity between their ISP’s entry point and the Orbis is not the problem.
- Mark as New
- Bookmark
- Subscribe
- Permalink
...but it is the problem and that's an uninformed approach.
Example - Orbi uses the 802.1D spanning tree protocol. This is a legacy protocol (WAY older than the Orbi itself). Most newer hardware runs Rapid STP (802.1w). These protocols have diffferent port states and so there has to be a "handshake" so-to-speak to switch protocol states between the two devices. There is then a keep-alive sent every two seconds to keep sync. Normally these STP differences are inconsequential, but not always true:
https://community.netgear.com/t5/Orbi/Orbi-STP-BPDU-errors/td-p/1329948
Assuming somethig is perfect because it works for you is not the way to solve problems.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Really?
It's just like that? How incredibly foolish business practices!
I really liked the beta 2.1.3.4 firmware, is there any way to foolish the system by renaming the firmware internally and reinstall that version?
Thank good for Costco's electronics return policy.
- Mark as New
- Bookmark
- Subscribe
- Permalink
@globespy wrote:
So no working ipv6?
Really?
Downgrading firrmware is supported. You don't even have to fool it. Just login in to the web interface and manually apply the older version. I would also suggest reseting the devices after applying the downgraded firmware.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I found that my Orbi auto upgraded its firmware. I'm curious what's to keep it from doing again if one downgrades?
