Reply
Highlighted
Re: Orbi firmware update v2.1.4.16 availability
So I received my RBK23 yesterday, it actually configured automatically, everything worked find until.... I tried to hook it up to ethernet! The nightmare began, sleep was lost, I was ready to throw it out of my window, almost literally!!
I have 2 houses though and in my other house I have a Linksys Velop system. I don't have ethernet in that other house so I thought, let's switch! I hooked up the Orbi in my ethernetless house and it was configured it no time to work wireless. Everything great. Then moved the Logitech Velop to my new house, hooked it up to the ethernet and ... it worked flawlessly!
So long story short, this ORBI unit is great for wireless (it's faster and it reaches further than the Velop). But if you have ethernet, just go for the Logitech Velop instead
Message 626 of 809
Highlighted
Guru
Kind of depends on what you have on your network and how it's all configured. I for one and others have wired back haul working just fine:
https://community.netgear.com/t5/Orbi/Orbi-firmware-update-v2-1-4-16-availability/m-p/1592753/highli...
https://community.netgear.com/t5/Orbi/OrbiOS-2-1-4-10-kills-Internet-access-if-you-use-Ethernet-back...
https://kb.netgear.com/000051205/What-is-Ethernet-backhaul-and-how-do-I-set-it-up-on-my-Orbi-WiFi-Sy...
https://community.netgear.com/t5/Orbi/Orbi-wired-backhaul-performance/m-p/1548397/highlight/false#M2...
https://community.netgear.com/t5/Orbi/I-found-a-Connection-issue-Resolution-for-wired-backhaul/m-p/1...
https://community.netgear.com/t5/Orbi/Orbi-firmware-update-v2-1-4-16-availability/m-p/1585890/highli...
https://community.netgear.com/t5/Orbi/Orbi-firmware-update-v2-1-4-16-availability/m-p/1585994/highli...
Disable IGMP on Managed Switches:
https://community.netgear.com/t5/Orbi/Orbi-MR-2-1-Update-3-23-18/m-p/1553749/highlight/true#M30673
https://community.netgear.com/t5/Orbi/Using-Router-Configured-as-Access-Point-Cannot-see-Satellites-...
My Setup (Cable 900Mbps/50Mbps)>CAX80>Orbi RBK853 v3.2.15.2#(Router Mode)
Additional NG HW: C7800/CM1100/CM1200, Orbi CBK40, Orbi RBK50/RBK853, R7800, R7960P, EX7500/EX7700, XR450 and WNHDE111
Message 627 of 809
Highlighted
Yeah I have read your posts, tried it all, nothing worked, my whole network would lose connection every time. I read somewhere this ORBI was made with wireless in mind, I think that's the key. It might work for some but obviously quite a few others can't get it to work. I just gave up, switched to Linksys Velop and it worked out of the box, configured automatically without me having to enter anything manually at all.
Message 628 of 809
Highlighted
Guru
Possible that there was bad HW involved as well. Have seem some bad Orbi systems go back to NG as well.
Also cabling and any network switches can play a roll in all of this as well.
Well enjoy what you got.
Message 629 of 809
Highlighted
Well I just have an unmanaged switch and a cable modem/router. One thing that is different though is that Linksys advices to place the parent node between the modem and the switch and then connect the child nodes to the switch:
Netgear advises to connect all the nodes to the switch:
Anyway I just gave up, my nightmare is over and everything works fine now in both of my houses (orbi wireless and Velop wired haulback)! If anybody else is having this ethernet haulback nightmare, you might want to switch to Linksys Velop too.
Message 630 of 809
Highlighted
Guru
Thats only one method to connect the satellites to the router. You can connect 1 directly to the router and another thru a non managed switch if needed. The NG and Linksys methods are the same.
I have mine connected to a non managed switch. Been working fine since day one.
Anyways, enjoy. Smiley Wink
Message 631 of 809
Highlighted
Good evening. If your system works fine then I would apply "Never change a winning team". So no. Don't update.
If you find in the release note anything which interests you, then you should update. The 16 release fixed for example the HomeKit connectivity. If you don't have HomeKit then you don't care. If you have HomeKit and it works then you don't care neither.
Bottom-line: Avoid this update if you can wait for a better release, and don't have regrets.
Regards
V.
Model: RBK53| Orbi Router + 2 Satellites Orbi WiFi System
Message 632 of 809
Highlighted
Guide
I also gave up with the Orbi system.
If someone is looking for something that works....try TP-Link DECO M9
Installed it four days ago and did the setup in 1 hour....Because of the fixed IP adresses :-)
It just works like it should!!!
I am not ussing the IFTTT option that is build in, for me it's just the wifi that needs to work in every corner of my house.
And that it does I have a strong signal and great speeds everywere in the house...
Also the virus protection is working properly so now i don't need to think about that either.
So if you are looking for something that just works....go for the DECO M9 :-)
Model: RBK22| Orbi AC2200 Tri-band WiFi System
Message 633 of 809
Highlighted
Guru
What FW are you currently using?
I presume your system is working ok?
Regards
V.
Message 634 of 809
Highlighted
Guide
Thanks for your advice! I do not use Homekit, so no advantage to updating!
Message 635 of 809
Highlighted
Guide
v2.1.4.10
Message 636 of 809
Highlighted
Luminary
On this version of Firmware 2.1.4.16 if a satellite is attached via wired backhaul should it show in the connected device list of the main unit or should show as "attached Sattalite"?
Message 637 of 809
Highlighted
Guru
Attached satellite and the connection should show as wired.
Message 638 of 809
Highlighted
Tutor
I fully agree
the router + satellite is really unstable, it's unacceptable !
no response and support from Netgear.
Message 639 of 809
Highlighted
Guru
How so?
We need more details about your situation and experiences. Maybe we can help you out. Other are having good experiences with there Orbi systems.
@vinz59 wrote:
I fully agree
Message 640 of 809
Highlighted
Apprentice
Vinz59, I concur with FURRYe38.  Your post is too brief, and also you don’t tell us what model Orbis you have, and you assume we understand when you say “I fully agree” - With what do you fully agree?
Then you say “the router + Satellite is really unstable”.  They are not unstable, which is probably the reason Netgear hasn’t responded.  You either have faulty units that should be returned, or your problem is due to the way you have set them up and/or your underlying network infrastructure.
Give the community more details of your setup and what has gone wrong for you.
Model: RBK50| Orbi AC3000 High-Performance Tri-Band WiFi System
Message 641 of 809
Highlighted
Apprentice
Gave this release a whirl yesterday, upgrading my RBR50 from 2.1.2.18 (1 sat, wireless 5G backhaul which reports Good). It was OK during the day, but the minute the HD streaming started in the evening it rebooted 3-4 times. Load still seems to be a problem for Orbi and I'd say this release is terrible. I also don't really consider two HD streams "heavy load" for a 400 dollar box.
I honestly wish I had never bought the thing. Every release in 2.x train has had massive problems, which kind of settled down in 2.1.2.x to "tolerable" levels. But since then it has gotten worse. Also, seems like it really went into a tailspin right after my warranty expired. So perhaps this system really is only designed to last a year. Who knows. When I first got it had issues with Ring doorbell I should've just returned it then rather than work through it.
Message 642 of 809
Highlighted
Tutor
Thanks  FURRYe38 and cheshbr for your post
You are right I can detail more my issue.
I have 1 router RBR40 (router mode) and 3 satellites in mesh mode RBS40. running firmware 2.1.4.16.
the 3 satellites randomly reboot during the day (around 10 times each).
Same issue with a reset factory of all the devices.. the config is really simple, I didn’t change anything more in the Orbi configuration.
I didn’t have the issue before with 2.1.3.x firmware.
Any idea or help will be really appreciated. I don’t know what can I do to solve this nightmare
thanks
Model: RBK40| Orbi AC2200 WiFi System
Message 643 of 809
Highlighted
Guru
Has a power cycle OFF for 30 seconds the back on been performed since the v.16 FW update?
What is the Mfr and model# of the IP modem the Orbi is connected too?
What is the distance between the router and satellite? 30 feet is recommended in between them to begin with depending upon building materials.
MIMO, Daisy Chain, Fast Roaming, IPv6. Save settings and reboot the router and satellite(s).
thanks
Message 644 of 809
Highlighted
Apprentice
Dont waste your time trying futile efforts.
The firmware is faulty or incomplete.
IMO, the more sats you have, the more issues you'll see.
NG has major work to do to resolve the issues which seem to have more to do with DHCP crashing due to the Sats backhaul.  Something is amiss.  Im no engineer, but it's pretty clear that they've not solved the issue.
If you have basic needs, you'll have no problem with the Orbi. If you have a complex setup, with high use, lots of devices, the system cant handle it.
So, while some folks want to help, you'd best be served by watching for the next firmware release.
Message 645 of 809
Highlighted
Guru
Lets try to help him first and see if there is a problem else where or with FW. Doesn't hurt to try a few things first while we all wait for the next FW update even though others are having good experiences with current FW versions. Not everyone is having bad experiences. Takes some effort to troubleshoot what the real issue is. It's not always FW.
Message 646 of 809
Highlighted
Apprentice
A system that requires specific actions, disabling of features/functions, or specific hardware to allow it to work is not "troubleshooting" ... it's a flaw that cannot be fixed by bandaid approaches.
Message 647 of 809
Highlighted
Guru
And you can certainly believe that.
Meanwhile I'll continue to try and help others and help find the real issues.
Message 648 of 809
Highlighted
Apprentice
People who say things like that tend to have zero concept of how wifi, networking and hardware work. And if one can’t do any sort of troubleshooting and complains about how there stuff doesn’t work, tends to just be lazy. At least some people on here are trying to help other people with there problems and seems to be making some people happier with there stuff. If your not going to help and be a hinderance, why not move along and let those do real work and help others. There zero benefit if your not helpful.
Arris 6183
R7800
RBK50
Message 649 of 809
Highlighted
Luminary
It doesn’t. Mine has been up and operational since December without a single issue they two automatic firmware updates
RBR50, 2 RBS50's AP Mode, wireless backhaul
Message 650 of 809
