- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Orbi firmware update v2.1.4.16 availability
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Re: Orbi firmware update v2.1.4.16 availability
AMAZING Guys.
OK so I had a bit of time when I there was no one needing stable internet at home. (No one working from home, Communicating with loved ones overseas etc) So I thought I will give the Ethernet Backhaul another try.
I did try twice before, Once before manually upgrading to 2.1.4.16 and then again after. But both times I plugged the Satelitte into A Network Switch that was then connected to the Orbi Router.
Both times loss internet almost instintly, I didn't leave it the 5 minutes only found that out after the second attempt That is what I was going to try this time around, if it goes down wait 5 minutes to see if traffic comes back.
This time when I tried it. I used the LAN cable that was connecting my Switch (where the Satelitte was located) in my office directly into the Satelitte then the switch into the Second port of the Satelitte. And no loss of network at all. Just an intermim blip in my office for my LAN devices when I juggled the LAN cables. And testing since I have had no loss of internet at all.
Since the Ethernet Backhaul went in I have notice no difference at all with my WIFI devices connecting to the Satelitte when it has Ethernet Backhaul or WIFI backhaul.
Before going for the Orbi RBK50 system I did have a Nighthawk R8000 where the 5GHZ was a bit patchy some times in where my office was, That was the only reason why I wanted the Ethernet backhaul But it does seem that the WIFI link between the 2 ORBI units, works brilliantly. I will report back say after a week, or if I start having issues
From New Zealand, 950/450MB Fibre connection, RN316 NAS, Orbi RBK50
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
I had a breakthrough with my ethernet backhaul.
Until yesterday (13/6/2018) i was using the 5Ghz wifi backhaul. Earlier in the day I did a factory reset, reinstalled V2.1.4.16 and then tried connecting the dreaded cable. My backhaul cable, at the satellite end, goes through a TP-Link 5 port switch, but at the router end, I connected it directly to one of the Orbi router RJ45 ports. Within seconds all turned to sh*t with lots of magenta ovals.
Where to from here? In desperation I swapped the cable from one of the Orbi router's RJ45 LAN ports to the one next to it, and within seconds - yes folks, seconds, i kid you not - my router Attached Devices list showed under Connected Satellites, Connection Type: Wired. And it remained stable.
What magic was performed? I can't explain, but I'm sure you will recall instructions for the use of USB ports that if it doesn't work in one, try another.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Whats the model# of this TP-LInk switch you were using? Managed or Non managed switch>?
Bad cable?
Additional NG HW: C7800/CM1100/CAX80/CM2000, Orbi CBK40, R7800, R7960P, EX7500/EX7700, XR450 and WNHDE111
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Bad cable?
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
You're not alone. I was using my iphone last night and I noticed i lost internet, it was connected to WiFi but said it had no internet connection, I noticed my son was streaming netflix on the apple TV still though. I had to turn WiFi off on my iPhone 6S Plus and turn it back on, and all was fine.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Exact same issue.
They know over there at NG. They are 100% aware of the problem per my support tickets.
Dont waste your time factory resetting anything. Its an exercise in futility.
It's a matter of waiting for them to solve the issue.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
The TP-Link switch is a $30 basic 5 port switch. You only need managed switches on enterprise networks with complexity requiring administrative oversight. Overkill on a domestic network. Cables are all cat 6, and current.
I now have the Orbis working as they should, in AP mode on V2.1.4.16, with wired backhaul.
I have a single cable from my modem to the yellow RJ45 on the Orbi router, a cable from a LAN port on the router to a 16 port switch, and a cable from another router LAN port directly to a patch panel, bypassing the switch, which services the satellite via the 5 port switch. There are around ten devices on the 16 port switch, such as a printer, a NAS, an iMac, MacBook, PC, links to ports in other parts of the house for smart TVs and games machines. Right now, everything works.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Well in theory yes, managed switches were meant for enterprise environments, however they have been trickling down into the home envirionment, no sure why or how. Possible that some users don't know or understand what there getting.
So reason for asking. Mangaged switches seem to give problems with the Orbi systems.
Sounds like it may have been a bad cable or something.
Glad you got it working. I get to start a RK53 install saturday.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
For those having the random reboots and disconnects from the Sattelites, I'd like to share my experience that I think may help. I have the RBK53 from costco (1 RBR50 and 2 RBS50s). I was having the issue that many have been complaining about regarding constant disconnects and random reboots. After looking at my 30+ devices, I realized that some of them were attempting to connect to the same IP address as the sattelites, causing all this mess. Everytime there was a reboot, the sattelites would come back with a different IP. I went in and set both sattelites to static IPs of 192.168.1.2 and 192.168.1.3, and then set the DHCP range from 192.168.1.4-50 and have not had a problem since. I will try the newest firmware, but I doubt that I will have any issue moving forward as the previous 4 firmware updates have been stable. Give it a try, and I hope it helps some of you out.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
still no v2.1.4.16 on auto update
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Meanwhile I’ll be on my work conference call tomorrow and the internet will crap out on me.
Wow the Orbi is great.... when it works which is 50% of the time that I have owned it.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Same, I have router plus three satelites - if I try to go ethernet backhaul to compensate for the satelites going good/bad often - everything goes offline. Had to disconnect the orbi satelites from the gigabit network and unplug the router to get networking back.
Had these mesh systems for a few months now, have not been able to get rid of my random wifi AP's because I can't depend on this expensive secondary system that doesn't work all the time.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
How does the Satelittes talk to the router? direct LAN cable or going via a switch?
I found if I plugged the Satelitte into a Switch in my Office the connection drops. But if I plug the cable directly into the back of the Satelitte directly back to the Router Unit and then the switch into the next port of the Orbi it has been stable as.
I have also plugged in to the ethernet port on the far left (if looking at the back of the unit).
Been stable for over 24 hours now. Will thrash over the weekend and see how it goes
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Been running this firmware since Sunday evening. Been rock solid throughout the week. Using wireless backhaul - and happy to report that not only is the router not crashing & rebooting 4x a day like it was previously but everything is remarkably faster. The fastest I used to be able to get off the satelite was around 250mbps on the previous 2.1.4.10 firmware - now its in excess of 400mbps on a Macbook Pro - 350mpbs on Apple TV & other iOS Devices. My homekit devices also respond more reliably as well.
If Netgear takes this firmware and launches it untouched - and allows us to lock this guy in - I'll be a happy customer. 2.1.4.10 was horrible - hopefully they have more quality controls in place to prevent that disaster from happening again. Love this product - but one forced firmware update of hell can tarnish it quickly.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
When will the day come when Netgear will have their own devices talk to each other? ORBI main unit and satellite done connect via backhaul using Netgear Nighthawk switch R8000 in between .
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
I have a Billion 7800VDOX VoIP modem/router, with WiFi disabled. A single cable from the Billion goes to the Orbi router's yellow WAN port.
At the router end, an ethernet cable goes directly from an Orbi LAN port to a patch-panel, and at the satellite end, a single cable emerges from the wall socket to a 5 port switch, which distributes ethernet to a smart TV, an Apple TV, a FetchTV STB and the Orbi satellite. You are right. I could cable directly from the wall socket and use the Orbi Sat as a switch. But I don't have to do that now.
My signal strength is incredibly strong. I have attached a graph showing a snapshot of my signal strength taken from the router end of the network in my study. The pink line shows the 5Ghz network in my study, at 97%, and the green line shows the signal strength of the 5Ghz network at the satellite about 15 meters away in my Family Room. From the study, the 15 meter-away satellite shows about 60%, but if I take my laptop to the Family Room, the green and pink lines swap position with similar percentages. The orange and yellow lines show 2.4Ghz network.
Having worked hard to get this outcome, I'm employing the attitude that if it ain't broke, don't fix it.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
I mentioned in earlier posts that my Orbi system under V2.1.4.16 works with wired backhaul and is very stable.
I was asked if I would work with L2 support, which I did. During my discussion with L2, I raised two issues
- I suddenly fluked achieving wired backhaul after an hour or two of alternating magenta ovals, by swapping the backhaul ethernet cable plugged directly into a LAN port on the Orbi router from port 2 to port 3. Almost instant connection, no magenta ovals. On one hand, this is a monumental achievement, but on the other hand, does it mean the Orbi router port 2 was fauly? I couldn't let that one pass, so I raised it with the L2 support guy.
- I also discussed an issue, probably unique to me, about my Orbi router not producing a signal strength anywhere near the equal of the satellite, which he said should be very similar, subject to the local environment. He suggested I seek a replacemet fgrom my Orbi vendor under warranty, which I did yesterday afternoon (14/6/2018)
Prior to swapping my Orbis for new ones, I backud up my settings. Then I set up the new Orbis fairly quickly. I enabled AP mode as soon as I could, upgraded FW to V2.1.4.16, restored my backed up settings, and was operational within an hour. Then I connected my backhaul cable to the Orbi router, and after power-cycling each Orbi, the router attached devices showed the satellite as "wired". It's now 24 hours since I did that and everything is stable, signal strength is strong, 5Ghz devices capable of 2.4Ghz and 5Ghz connect as 5Ghz, and all connected devices have aligned to the nearest Orbi.
For general info, my Billion 7800VDOX modem/router connects to the internet, and handles all DHCP, NAT, firewall and security duties. The Orbis are in AP mode. In the Billion, I have set up reserved IP addresses in the DHCP table for all devices that permanently connect to WiFi, so the Orbi router's attached devices list clearly identifies each object by name. I think this improves efficiency of operation and stability.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Feedback/status report for @BretD
Having run 2.1.4.16 for a while now—a week maybe?—it has improved HomeKit. I cannot think of finding a device unresponsive since applying it. I have iDevice wall "switches", Lutron light switches, and a Hue lightstrip run from an AppleTV as the hub.
So far as iOS devices dropping off the WiFi, despite having a very strong signal, that's still happening, although, I'd say it's happening much less than before (but still more than a few months ago when this whole mess started.)
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Is any of the following enabled on the router? Beamforming, MIMO, Daisy Chain or Fast Roaming?
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
I thought at first this fw had solved my wired backhaul problem but it was short lived. The wired satellite start going back and fourth between wireless bands, both with a “poor” signal level. I am in router mode so I may switch to AP to see if that makes a difference. About to the point of giving up if that does not work.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
You say you are in router mode and plan to switch to AP mode. To do that you need a separate third-party router between the internet entry point to your house and the Orbi in AP mode. Or are you running two routers?
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Rif.: Orbi firmware update v2.1.4.16 availability
@manuel-c23 wrote:
RBK40, v2.1.4.16
1) Ethernet backhaul issues after reboot are not really fixed and I'd say they are even worse than in v. 2.1.4.10. Internet connection doesn't work and I get the yellow triangle on Windows.
2) On Windows, I get 3 on 4 wi-fi bars instead of 4 on 4 bars at about 40 cm (15 inches) from the satellite. How is that possible? The signal strength should be at maximum level when I'm so close to the satellite.
3) Internet connection is sluggish, I can't watch a video on YouTube without continuous freezes.
@manuel-c23 wrote:
I just did a speed test, I have a 40 mbit/s Internet connection, but I get under 1 mbit/s from the Orbi satellite, and I'm at 40 cm (15 inches) from it (Ethernet backhaul).
I believe I found the cause of issues 2 and 3... and the cause is related to issue 1.
I was at about 40 cm (15 inches) from the satellite, but I was probably connected to the router instead of the satellite, so the signal was weak.
However, I couldn't get the ethernet backhaul connection to reliably work in v2.1.4.16, so I reverted back to v2.1.4.10 (which is also not reliable, but it's better than v2.1.4.16).
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Chesbr,
i am only running one router (the orbi). I do have an old Netgear 3400v1 that I would use as the main router should I decide to use the Orbis in AP Mode. It would give me better qos, just not sure if switching orbi to AP mode would help. It really seems that Netgear would be able to provide a setting in the satellite to “force” it to a wired backhaul and avoid all confusion.
