- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Orbi firmware update v2.1 fail
- Mark as New
- Bookmark
- Subscribe
- Permalink
ok, i'm trying to manually update the firmware. so i got through the login page, get to the advance menu, click on manual, select my satellite and tap the update button. this is what i get -- on Safari, Firefox and Chrome:
<html><head><meta http-equiv='Pragma' content='no-cache'><meta http-equiv='Cache-Control' content='no-cache'><title> 401 Authorization</title> <script language="javascript" type="text/javascript"> function cancelevent() { top.location.href='/unauth.cgi'; } </script> </head><body onload=cancelevent()></body></html>
ok. java and javascript are enabled on my mac, running high sierra 10.13.2. i can't seem to get beyond this point. can anyone help? it's much appreciateted.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Orbi firmware update v2.1 fail
Have you tried to power cycle the satellite before trying to do the update?
DarrenM
- Mark as New
- Bookmark
- Subscribe
- Permalink
thanks for the reply. since the update was pulled, should i just wait?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Darren, should i wait until the firmware update is officially reposted?
- Mark as New
- Bookmark
- Subscribe
- Permalink
You can wait if you do not need the new features of circle parental controls and ethernet back haul but when trying to manually load the firmware did you unzip the file you downloaded before trying to load it onto the orbi unit?
- Mark as New
- Bookmark
- Subscribe
- Permalink
yes, i tried to upload the unzipped file.
- Mark as New
- Bookmark
- Subscribe
- Permalink
the problem is that i never get to the point where i upload the firmware. as soon as a click the button to select the satellite for upgrading, and then click update, a new window opens with the message i originally posted. it happens immediately. it opens a URL with the router address slash fwupdate.html.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Just go to the main page of the satellite (remove the filename fromt he end fo the URL), login there, and then go to the fw update link.
- Mark as New
- Bookmark
- Subscribe
- Permalink
maybe this will help. i get to the firmware page, click the button to select the satellite, then click update and then i get this popup window.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Skip the firmware page on the router for now... go to the satellite directly: http://[IP of satellite]/
Once you log into the satellite interface, then there will be a firmware update link there.
- Mark as New
- Bookmark
- Subscribe
- Permalink
typing in the satellite IP gets me the same information i originally posted.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Very odd. In that case, I would do a re-sync between that satellite and the router, because if you can authenticate to one but not the other, their configs must be out of sync.
- Mark as New
- Bookmark
- Subscribe
- Permalink
UPDATE. the new version of the iOS Orbi app had an update that pushed the firmware update to my equipment. went off without a hitch. both the router and satellite are at 2.1.2.18.
