Orbi WiFi 7 RBE973
Reply
Orbi guest network setup
mach743
Follower
I've been running an unsecured guest network along with my secured network. Recently, I changed the open guest network to a password protected network becuase a neighbor was logging onto my guest network.  After doing so, two guest networks appeared on my system, one was secured, and one was open.
I turned off the password protection and my system reverted back to one open guest network.
Is there a way to have a secured primary network and a secured guest network, and no open guest network?
Model: Orbi High-Performance AC3000 Tri-Band WiFi System (RBK50)
Message 1 of 2
DarrenM
Sr. NETGEAR Moderator
Re: Orbi guest network setup
Have you tried to disable the guest network then try to re enable it and apply the password?
DarrenM
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 653 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
