Reply
Highlighted
Follower
Orbi has internet connection, but nothing will connect
On my orbi login I’m getting both internet and WiFi connections, all status is good. All satellites are connected. Yet, all my devices can’t and won’t connect to the router
Not sure what to do. I’ve tried the obvious of restarting the router as well as modem.
Model: RBR50| Orbi AC3000 Tri-band WiFi (Router Only)
Message 1 of 2
Highlighted
Guru
Re: Orbi has internet connection, but nothing will connect
What devices are you connecting to the router?
Have you power cycled these devices?
Clear out any prior wireless profiles or forget last used profile and set up new profiles.
Are there any other routers or wifi that these devices are connecting too?
Whats the Mfr and model# of the ISP modem the Orbi is connected too?
Besure your connecting to the Orbi's wifi SSID Name.
This SSID name seen by your devices?
Check internet access with a LAN cable connected PC as well.
My Setup (Cable 900Mbps/50Mbps)>CAX80>RBK50 v2.7.0.70(AP Mode)
Additional NG HW: C7800/CM1100/CM1200/CM2000, Orbi CBK40, RBK853, R7800, R7960P,
EX7500/EX7700, XR450 and WNHDE111
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 400 views
  • 0 kudos
  • 2 in conversation
Announcements
